Old 09-02-2014, 12:57 PM   #31
vinmaker's Avatar
Originally Posted by bikendan View Post
No. One side is always silver and the other side can be be different colors.
I was asking about refletix. Reflectix comes in different colors?
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-02-2014, 12:58 PM   #32
vinmaker's Avatar
Originally Posted by dado39 View Post
I use pugs shiny side up and I use a product called Eco foil nicer than reflective white side out shiny side in works great in the heat and cold I also put it under my pugs .
Double Bubble Insulation - Ecofoil Reflective Bubble Insulation
So you have the gizomo's AND you use the Eco foil? Where do you use the Eco foil? I made some cheap Gizmo's out of Reflectix. The Eco foil looks like a similar product.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-02-2014, 02:16 PM   #33
I have the Gizzmo's that I bought for my Popup, I use them on my Hybrid now. They are a little longer (King vs Queen) but the fact that they do wrap around the end a little is OK, it adds a little more darkness.
Another nice thing about teh Gizzmo's is that any tree sap, leaves, or bird droppings fall on it, so when your done camping and you take them down, you can just hose them off at the Car Wash or in your driveway. Your canvas stays clean!
Uncle Buck is offline   Reply With Quote
Old 09-02-2014, 02:42 PM   #34
vinmaker's Avatar
That is the main reason I want them is to protect the canvas.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-02-2014, 03:00 PM   #35
Jimandchris's Avatar
Many use the reflectix or ecofoil material to make inserts that gets placed between the screen and zipped portion of the bunk ends. It gives some additional insulation properties to the bunk ends. Also helps some with the darkness.
With pugs on the top and reflectix in the three "window" sections of the bunk ends, there is significant improvement in keeping it cool or warmer.
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 09-02-2014, 03:04 PM   #36
Here is a pic of ours this spring with the reflectix panels and the pugs
I used kraft paper to make templates of the window sections, then cut out the reflectix to match.
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 09-02-2014, 03:19 PM   #37
vinmaker's Avatar
Ah ok. Thanks. I get it now.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-02-2014, 03:28 PM   #38
No problem, Vin. That's what the forum is for. I was asking similar questions about this time last year in anticipation of our Roo purchase.
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 09-02-2014, 05:25 PM   #39
dado39's Avatar
I also put it under my pugs on top of tent ends
2014 roo 233S. 2008 saab 97x
dado39 is offline   Reply With Quote
Old 09-02-2014, 05:46 PM   #40
I'm a bit leery of doing that. Worried that the aluminum would eventually rub off on the vinyl. Your ecofoil would be better for that use though. Do you think its helps much?
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
