Old 12-09-2010, 03:11 PM   #1
samsc03's Avatar
Furnace Shutoff
Hello,
We have been using our furnace on our trips this time of the year. Got a question that I need to ask.
When I went to go hookup the other day I connected the battery like I always do since I disconnect it everytime when stored, the heater fan kicked on. The gas was off of course and the thermostat is pushed all the way to the left as an attempt to have it cut it off. I had to pull the fuse to get it to shutoff.
Any suggestions as to the correct way to shut it off? Don't like pulling fuses as a means for a switch.
Sam and Tonya
2011 Shamrock 19
2003 Toyota Tacoma V6 4wd
Tekonsha Voyager
Equal-I-zer
samsc03 is offline   Reply With Quote
Old 12-09-2010, 03:38 PM   #2
okdrifter's Avatar
I have a fan [on off] switch on the thermostat. also it has[ furance -off -cool switch] try that if it's the same.
Doug and Carmin
2010 Wildcat 31TS
2008 F-250 King Ranch
okdrifter is offline   Reply With Quote
Old 12-09-2010, 03:40 PM   #3
Dave_Monica's Avatar
Originally Posted by samsc03 View Post
When I connected the battery like I always do since I disconnect it everytime when stored, the heater fan kicked on.
Sam and Tonya
Strange!
Was the thermostat switch set in the off position or in the heat position?
Dave
Old 12-09-2010, 03:45 PM   #4
samsc03's Avatar
well the thermostat only controls the heat. So I took the face off the thermostat to assure we were not missing the switch on it and ther is not one on it at all. Just the temp adjustment.
Sam and Tonya
2011 Shamrock 19
Tekonsha Voyager
Equal-I-zer
Old 12-09-2010, 04:02 PM   #5
If there isn't a switch it turn it off, the furnace will light and the fan run whenever the temperature is below the thermostat set point.
Check in the beaker panel for a disconnect...the furnace fan will also have a fuse on the 12V side.
Dave
Old 12-09-2010, 04:14 PM   #6
samsc03's Avatar
I don't know maybe i missed something. All I can figure is that the breaker is the only way. It seems to be a real nice panel too. LED's for disconnected or blown fuses. will look into the situation later.
Sam and Tonya
2011 Shamrock 19
Tekonsha Voyager
Equal-I-zer
Old 12-09-2010, 09:17 PM   #7
caper's Avatar
Is this the style you have. If so if you move the lever all the way to the left it should turn off the furnace. If it is not in the off position the furnace will run even with the gas turned off. You will not get heat.
Old 12-09-2010, 10:16 PM   #8
IF your thermostat Has fan on- auto setting change it to Auto. The next thing it maybe a fan limit control stuck close or control broad on the frizzes . Just what model do you have?
2010 wildcat 31ts
05 Ford F350 SD PS
camprat is offline   Reply With Quote
Old 12-09-2010, 10:28 PM   #9
Eric F.'s Avatar
If yours looks like caper's I had the same problem. Just push it to the left till it stops, then push a little harder and it will move a litle bit more with a pop and that will switch it off.
Eric F.
2015 Flagstaff Shamrock 233S
2012 Ford F250
Eric F. is offline   Reply With Quote
Old 12-09-2010, 10:41 PM   #10
Mine works the same way - have to give it that extra push in the off position.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
