Old 04-18-2013, 08:45 PM   #1
Question Giving trailer a lift ??
Hi FRF,
Do they make kits to raise the height on a travel trailer? My family's Roo M232 is giving me a little bit of a hard time clearing my driveway since its a bit up a uphill and because I will also like it to ride a little bit higher.
2RLfUnfAmCamp is offline   Reply With Quote
Old 04-18-2013, 10:07 PM   #2
jonnys_walkers's Avatar
When we purchase our unit we had the dealer flip the springs.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 04-18-2013, 10:10 PM   #3
caper's Avatar
if you do raise the trailer it will change the center of gravity and will effect the way the trailer will handle when towing.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-18-2013, 10:14 PM   #4
Dave_Monica's Avatar
The Roo has torsion axles so the only way to lift them is to install a length of square or rectangular steel tubing spacer block between the camper frame and the axle mounting. Cross braces between the spacer blocks should also be installed.
Have you tried removing your W/D bars before backing up the driveway...it may be enough change for the rear of the camper to clear.
Dave
Old 04-18-2013, 10:35 PM   #5
bikendan's Avatar
Dave's right, you can't "flip" a torsion axle.
many have gone to a RV shop and had the spacers installed, especially on Jayco Hybrids, which are famous for being too low.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-20-2013, 09:25 PM   #6
Well I've only backed it up only once to the side of my drivve way since I bought it, havent gone camping in her yet. So I didnt have the W/D on, just regular hitch & ball. It is torsion axle like you guys said, and thanks for the suggestion i will contact the Dodds RV and inquire about getting some spacer installed, that sounds like a good idea. Thanks all for your responses.
