Old 08-26-2016, 02:18 PM   #1
Hooking direct tv up to my 2013 233s...
We have a portable dish we take to tailgates, the Roo is going with us this year to the games. My question is can I just screw the coax cable from the dish into the back (where you would hook campsite cable up) and then run another coax to my direct tv box on the other side and the satellite work or will I have to just run the coax directly to the box for the outside tv and bypass the camper?
Thank you!
Uvafan15 is offline   Reply With Quote
Old 08-26-2016, 02:57 PM   #2
Broken Toe
Cowracer's Avatar
As far as I know, that should work. Should be easy to try out at home I the driveway
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 08-29-2016, 08:38 PM   #3
I have a 2013 233S also, on my RV backside between the slide out and side bunk I have an outlet with 2 cable connections, one for campground cable and the other for satellite. Both of these connections go to the same 2 jacks behind the TV.
theengle is offline   Reply With Quote
Old 08-29-2016, 08:41 PM   #4
Mr. Dan's Avatar
Do what Tim Cowracer suggests: try it at home first. I have 2 Sat Ins and 1 Cable In on my Wildcat so I had some experimenting to do... and it wasn't so easy at a remote campground in south central Oklahoma!
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 0
Old 08-30-2016, 01:29 PM   #5
Take The Road Less Travld
MuddauberE's Avatar
We have the same trailer. The outside coax inlet on the back will activate all the access points in the trailer. Just hook up your receiver to one of them and then connect that to your TV. In that situation, I would move the TV outside and hand on the outside mount and connect the box to the coax out there; assuming your satellite will need to be on the back side of the trailer for a good signal anyway.
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
2013, 233, 233s
