Old 12-22-2012, 01:04 PM   #1
Jus' Gettin' Started...
74Fox's Avatar
Hot water using electric but not while using gas?
Hello All,
We has a wonderful time this year as first time campers in our 2006 Shamrock 23rs. There was only one thing that puzzled us. Our water heater worked just fine while hooked up to electricity. However, when we fired the water heater up on propane;the water never got hot.
The water heater pilot was lit.
The flame was normal and blue.
What did we do wrong? What else should we look for? Are there additional steps for getting hot water with propane that we are missing?
The previous owner that we purchased the camper from had the same experience and wasn't sure how to resolve it. Your advice is greatly appreciated! :-)
Our First Home Away from Home!!
06 Shamrock 23RS
74Fox is offline   Reply With Quote
Old 12-22-2012, 03:41 PM   #2
wmtire's Avatar
74Fox, do you know offhand what brand/model water heater you have?
I am assuming, that it is a pilot light model (not dsi) and you had your gas valves open on your tank(s), and they had fuel in them
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 12-22-2012, 03:47 PM   #3
TURBS's Avatar
Originally Posted by 74Fox View Post
Hello All,
Is the Hw switch on?
Turbs
Old 12-22-2012, 04:40 PM   #4
74Fox's Avatar
Yes to the following:
1. Tanks full
2. Gas is turned on (stove range and oven operate without issue)
3. Water heater switch is turned on
4. Pilot is lit (normal shape and blue, no orange flame)
Our hot water works fine when camping with an electric hook up.
We don't get hot water when using propane, the water just runs cold.
The model of the water heater is: SW6, Suburban Direct Vent Gas Water Heater
06 Shamrock 23RS
Old 12-22-2012, 05:33 PM   #5
VinceU's Avatar
1. Tanks full
Chane the gas nozzle, sounds like its plugged. CW or Suburban.
Old 12-22-2012, 06:12 PM   #6
jim44646's Avatar
OK your Pilot is lit. Does your main burner come on? You'll hear a roar like a jet engine. after pilot is lit is the knob turned to on position? Spiders love propane and could have a web in burner nozzel. can clean with canned air
jim44646 is offline   Reply With Quote
Old 12-23-2012, 01:28 AM   #7
wmtire's Avatar
Thanks 74Fox. There should be some more digits after the SW6, that will tell us a little more about your particular model (maybe a P or a PE perhaps). This info should be on a tag at the bottom right hand side of your water heater box (accessed from the outside of your trailer)
I just want to make sure of the exact model to narrow down the problems it could be with yours as Suburban makes a SW6 in a P, PR, PE, PER, D, DE, and DEM. All of these after letters tell us how your heater operates, and what to look for in the troubleshooting.
Here is a pdf file on the SW6 (and it's many models). Near the bottom of it are some troubleshooting guides, that are sorted by particular models (once you know your exact one).
http://waterheatertimer.org/pdf/Subu...ice_Manual.pdf
I agree with others that it could be a clogged tube, or maybe a faulty gas control (which I assume you are turning the gas control valve to the on position after lighting the pilot light in the pilot position).
Old 12-23-2012, 05:25 AM   #8
74Fox's Avatar
Thanks so much Guys for all of your responses! Hubby and I will get the rest of the model number and reply back also, we'll take a look at that tube that you all mentioned and give a status on it.
It just seems so strange that the hot water only works using electric and no one that we talked to around here ever heard of or, had an issue quite like that.
Thank God for this forum! You guys are the best! :-)
06 Shamrock 23RS
Old 12-23-2012, 05:45 PM   #9
jim44646's Avatar
No, not strange. 2 different heat sources. One's working other isn't. Electric uses an electric heat element. Gas burner runs off of propane. One has nothing to do with the other.
Old 12-23-2012, 06:13 PM   #10
If you have to light the pilot, you may also have to turn the gas valve from PILOT to ON.
