Old 01-29-2017, 11:29 AM   #1
Ron045's Avatar
How can I tell if I have heated pads for holding tanks?
We passed on this option for our new 23IKSS, but our unit came with the manual for heating pads. There is also a switch installed in the unit which lights up, vice a blank.
Is there a way I can check to see if I really have these?
Ron
Ron & Family
Junior Season (Max time with the kids before they graduate)
2017-23 Nights, 2018-30 Nights, 2019-23 Nights
2017 Shamrock 23IKSS
2016 Lincoln Navigator L, 4x4, 4.10
Ron045 is offline   Reply With Quote
Old 01-29-2017, 11:42 AM   #2
I have a new camper on order and was showed a spec sheet. List every option known to man for the unit and the boxes are checked or not. Did you get/see one for your unit?
I would think if the switch lights up that would be a yes on the heat pads. Of coarse my old hideout control panel showed two grey tanks and the light showed emptied when it only had one tank? I looked at a Rockwood and thought the heat pads were fairly "standard" now.
Prob pretty tough to open up underside of camper and look and to many variables to try and take temperature of water coming out of grey tank with switch on vs switch off.
Those pads are probably part of a "package" or group of options that all come together and if you have other options on your unit that coincide to that package or group you prob have.
Kimber45 is offline   Reply With Quote
Old 01-29-2017, 11:42 AM   #3
Ford Idaho's Avatar
Buy one of these if you do not have one, you will find it very handy.
Non-Contact Infrared Thermometer With Laser Targeting
Aim it in the area where you think the tanks are, turn the switch on and recheck the same area for any temperature increase.
You can also use it to check for hot trailer tires and bearings.
Old 01-29-2017, 11:51 AM   #4
I looked at forest rivers web page. then are standard as a package on the signature series but clearly listed as an option on the roo's, also shows thermal windows as an option? weird option for a hybrid. good luck.
Old 01-29-2017, 11:54 AM   #5
Ron045's Avatar
Yes... We declined the thermal Windows too. Figured the tent ends were zero R value so what would be the point.
Ron & Family
Old 01-29-2017, 12:10 PM   #6
can you measure electrical amps used (such as via a ems system)? if so measure the amps used in the trailer with the switches off. then turn the switches on and measure the amps again. if there is an increase is the amps used when you turn the switch on /off I would assume they are being used by the heater pads.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 01-29-2017, 12:32 PM   #7
bubbles's Avatar
This my not work due to the cut off temp for the pads. Every system I've seen uses black pads and if you can see the internals of your rig around the holding tanks and see a black looking pad material then chances are you have the system. I believe the light in the switch only lets you know that the switch is ON and not an indication of the system. Just a guess.
Old 01-29-2017, 12:41 PM   #8
glsimms's Avatar
An easy way to find out would be to contact the manufacturer with your VIN number. They should have the information for you.
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 01-29-2017, 01:06 PM   #9
Correct! Youroo!!
Old 01-29-2017, 01:11 PM   #10
SailorSam20500's Avatar
On my rig which has them, I can see a small pad on the pipes just before the dump valve.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
tank
