Old 09-14-2017, 07:57 AM   #1
How to change to LED?
Just purchased a new to me 2010 Rockwood Roo. When running the lights they seem to get pretty warm. Would love to change out the bulbs to LED. Is this possible and how do I do this? I figured out how to remove the lens but that's where I got stuck because the bulb just plugs in. Thoughts? The suggested replacement is a 12v type 921 I think. It's hard to read the stamping on the metal. Click image for larger version
ID:	151403Click image for larger version
Tccampergirl is offline   Reply With Quote
Old 09-14-2017, 08:17 AM   #2
Brother Les's Avatar
There are many 'sizes' and color hues on the 'light spectrum'. Some are push in, just as the one shown and some the 'push and turn' bulb type connection, but flat. They are costly and you will put out a lot of money to replace all of the 'bulbs'. I would suggest to 'check the lighting hues' and only buy one or two bulbs to see if you 'like' the color spectrum shade, before buying too many. There are many varieties and cost variants, so search around.
I have two in my unit and do not like them at all because they give out a 'bluish' light. barely use that light fixture.
Brother Les
Old 09-14-2017, 10:27 AM   #3
Head Rambler
That is a 921 lamp. I've replaced all the lamps in the last two RV's we've owned.
I bought Paddle Style 921 LED's
I like the 5000k color units, but a lot of people like the 2500k to 3000k units.
5000k is bright white, and 2500k is yellow, & matches regular incandescent color. If you like a good white light, go with the 5000k units and if you prefer the color of regular incandescent lamps, go with the 2500k to 3000k units. If you get much above 6000k they start getting blue in color.
As said above, if you're not sure which color you want, buy a couple of each and install them until you decide.
Gotta go campin!
Old 09-14-2017, 07:27 PM   #4
I have the same lamps and replaced the bulbs with
https://www.amazon.com/dp/B01A9J0TSO..._hkWnuSrEaRDCf
The light switches will stop working if left on with regular bulbs
Danx2 is offline   Reply With Quote
Old 09-14-2017, 07:38 PM   #5
crunchman12001's Avatar
Very inexpensive upgrade. I like the warm white 3500K - 4500K bulbs for general task lighting.
Here is a link for 20 bulbs for $12.00 on Ebay. Plug and play.
20x Warm White T10/921/194 RV Trailer 42-SMD 12V Backup Reverse LED Lights Bulbs
I did find the 42-SMD was not bright enough for the DW to apply the war paint so I bought some 68-SMD cool white for the bathroom. (6000K) She thanked me.
http://www.ebay.com/itm/10-x-T10-68-....c100005.m1851
2015 F-250 FX4
Old 09-14-2017, 08:20 PM   #6
There are tons of LED replacement bulbs on eBay. I personally like the warmest light I can get so 2500K to 3000K is what I look for.
LEDs are cheap if you search a little bit.
https://www.ebay.com/sch/i.html?_fro...+bulb&_sacat=0
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 09-14-2017, 09:00 PM   #7
Wow! Thank you all for the wonderful advice and links. This will be on my upgrade list asap. I really don't like how hot the bulbs get when using them and I'm sure the battery life will improve too. Now to figure out how to install a light switch at the door so I don't have to fumble around the ceiling to turn on a light.
Old 09-15-2017, 12:49 PM   #8
One of the first upgrades we did to our TT was to change out the bulbs to LED's. These are what I found on Amazon after doing some research.
GRV T10 921 194 24-3528 SMD LED Bulb lamp Super Bright Warm White DC 12V Pack of 10
These were the closest I could find to the color of the incandescent bulbs. They ran under $20 for 10 and out of two orders, there was only one which was a dud. We've been very pleased.
No more "too hot to touch" lenses either.
2016 Wildwood 230BH X-Lite
2011 Ford XLT Supercab
Days Camping -
'15 (6) : '16 (32) : '17 (41) : '18 (35) : '19 (10) :
Sebourn is offline   Reply With Quote
Old 09-15-2017, 04:52 PM   #9
Heat means current draw, make light not heat.
I kind if ticks me off my 2017 Palomino has all LED from the factory EXCEPT the outside light which is the one light most likely to want to leave on all night. So I too have one needing replacement.
Hersbird is offline   Reply With Quote
Old 09-15-2017, 05:24 PM   #10
I have the same issue for my porch light.
Bought this for a little more than a buck to try out. Haven't had a chance to put it in yet
1156 BA15S 18 LED 5050 SMD Car Turn Tail Brake Stop Light Lamp Bulb White 1141 | eBay
led
