Old 07-03-2016, 04:28 PM   #1
Hybrid Expandable Wintering in NJ ~ Skirting
/Users/sherrilberry-wysong/Desktop/nomadHome copy.jpg
As new first year full timers... (Solaire 190X Palomino with 3' slide out length of the hard body part of the RV) we will be wintering here at the Northern Jersey Shore. We have decided to skirt the rv and I have found several methods. It looks like the most popular method is with the snaps... and as we can't get away to drive to Colorado (working here) or South Dakota to have it done and fitted... I am looking for other ideas.
I've found the gluing suction cup/velcro guy, and the channel (like this idea) company, but I doubt they will come to Jersey to fit and make it for us.
Then there is the total DIY Idaho Canvas company... I take the measurements and figure out how to install the skirt company.
As well, there is the problematic issue of the tent bunk ends. Not much to adhere to... except underneath. I do have the windows done with reflectix and PUGS on the ends.
Any one have some constructive ideas?
And actually we are not crazy.
RV has a great furnace! Heated beds and we will be putting 1" foam board under the mattresses.
Thanks!!!
Wherever we go... There we ARE
Disa is offline   Reply With Quote
Old 07-06-2016, 05:30 AM   #2
Anyone???
Old 07-06-2016, 05:47 AM   #3
BamaBob's Avatar
You will definitely want to skirt your rig - what would concern me is how you are going to insulate the bunk ends maybe some sort of insulation under the bunk end toppers you have? And the ends - maybe insulation around the sides as well - again not sure how you can attach them though.
Not sure exactly where you are at but the low temps in January in NJ can get in the teens
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 07-06-2016, 06:01 AM   #4
BamaBob's Avatar
My wife just took a look at your setup and she has a great idea!
At Lowes you can purchase 4'W x 8'L attic insulation styrofoam sheets that have a reflective surface on one side (think aluminum foil) These will probably go a HUGE way to helping you out insulating your bunk ends and inside the skirting around the base of your RV.
Also halogen shop lights might be a good under bunk end solution - just be aware of the potential fire hazard.
DW just had another thought - they make these oil filled space heaters the work really well - use the CG's electricity and save on your propane They are fairly inexpensive - we bought a couple a few years ago to heat our 5th wheel:
https://smile.amazon.com/DeLonghi-EW...l+space+heater
Finally, consider getting a heated water hose:
https://smile.amazon.com/Pirit-PWL-0...+RV+water+hose
Hope these ideas help!
Old 07-06-2016, 06:04 AM   #5
Do NOT Try This!! This will Fail! When was the last time you were tested? Skirting looks nice,but Bales of Straw TOTALLY around you unit would be a better R factor,but would look like Hell! Go with another Plan,this one is doomed to Fail! Youroo!!
Old 07-06-2016, 06:09 AM   #6
BamaBob's Avatar
Also you will want to use that insulation to cover the top, side & bottom exposed sections of your slide out....
Old 07-06-2016, 07:13 AM   #7
Thanks for the tips!! The skirt is probably the way to go, because we sometimes have to be mobile quickly. The foam under the mattresses is good.
I did not know about the hose. That is cool. Looking into it.
I wonder... is it is more effective than heat tape and pipe insulation?
The campground requires the heat tape and pipe insulation.
I appreciate the replies. Does anyone have the skirting which uses turnbuckles screws and snaps?
Thanks!
Old 07-06-2016, 08:43 AM   #8
BamaBob's Avatar
Thanks!
Click on this link:
It will take you the the heated hot water hose on Amazon (It plugs in to 110v )
BTW if you are not a Amazon Prime member consider it - it's the full timer's friend!
Old 07-06-2016, 11:55 AM   #9
bikendan's Avatar
Anyone???
I think most haven't responded because we feel that a hybrid is a bad choice for what you're doing.
Only a tent or popup would be worse choices.
Equalizer WDH
Old 07-06-2016, 12:13 PM   #10
KenHwy61's Avatar
I agree. Bad condensation and possible mold will be among your many issues. Hybrids just are not built for sub-freezing camping. I would consider a different camper if possible.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
expandable, hybrid, winter
