Old 08-27-2015, 04:38 PM   #1
Wink Hybrid Trailers FYI
Just a couple notes so you don't have to go thru looking for the cause of the problem.
leaking bed ends, replace rubber seals, after being closed for long periods leave open for a day or two so seals can fully re-expand. Look at bed end door latches, these are adhered to trailer with screws, they will pull out causing leaking, I drilled thru and used carriage bolts. On a new or bed end that is not leaking seal with silicone the edge of the frame on the inside, if water gets in it will go thru to the hinge drain and not cause de-lamination damage. Forest River is awesome at getting you the proper replacement parts at very reasonable prices and helping answer any questions you may have.
dwolff is offline   Reply With Quote
Old 09-02-2015, 05:13 PM   #2
Another suggestion would be to condition the seals regularly with a seal dressing of some kind. Your dealer can recommend one. Keeps the rubber softer and more pliable, creating a better seal. Be sure to use it on slide seals also.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
hybrid, trailer
