Old 03-08-2017, 09:37 AM   #1
New Owner of a 2008 Too 23ss. TV question
I have signed the dotted line on a used in excellent condition 2008 ROO 23ss. My family is totally excited as this is our first camper! I cannot find the specs of the TV antenna anywhere and am asking for some assistance. I know this is right on the edge of the digital antennas and am curious if the one on my unit is an analog or digital. As stations typically do not broadcast analog anymore. Any help would be greatly appreciated.
fvrs7189 is offline   Reply With Quote
Old 03-08-2017, 10:01 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. The antenna doesn't really care if its called analog or digital it will work to some degree. Its the turner in the tV that make the difference between analog or digital. one is a broad signal one is narrow. the old Batwing Wineguard will pick up digital TV but when you add a Wineguard wingman you normally can pull in more signals. the biggest item to check is if the signal booster for the antenna works.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-08-2017, 11:19 AM   #3
Welcome to the forum and congrats on the new camper.
As to the antenna,some have upgraded and had success. A lot depends on the terrain and the distance to the station's transmitter.
Seems like if you're much more than 50 miles from the station, reception is problematic.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 03-08-2017, 01:35 PM   #4
bikendan's Avatar
There is no real "digital" tv antenna
You can get a digital signal using a rabbit ears antenna.
It's the tv that makes the difference.
Your antenna is a Wineguard batwing type, the same as I have in my 2007 23SS.
I get great high Def picture from the Wineguard antenna.
Digital TV antennas are one of the great marketing scams.
Equalizer WDH
Old 03-09-2017, 06:05 AM   #5
Mainframe's Avatar
I have always had TV antennas at my house, DW hates tv in general and has no taste for cable. I live on the second highest hill in my county so I have always pulled in great signals even back in the vhf days, I always bought the biggest vhf rig radio shack carried and used a rotor to get my signals dialed in, whenever they switched over to digital tv (using the uhf bandwidth) I bought a digital tv antenna from antennas direct (the thing was a fraction of the size of my old vhf rig and my rotor quit) hooked it up with a cheap walmart cable and BOOM 22 PERFECT channels! A clear perfect picture like I had never seen before!
All I did was aim it toward Pgh!
Fast forward to now, same digital tv antenna and my last scan netted me 55 free channels. All perfect hd on my 60 inch.
An over the air digital picture is perfect hd, no filters, the nfl games are perfect quality.
When I ordered the antenna, I talked to the owner of antennas direct and he told me his antennas were really enhanced uhf antennas, he has fine tuned them like crazy since and I am temped to buy 3 - 4 section antennas with amps built in and put them up like a trangle, fix my rotor and pull in what ohio is sending also some wv.
I saw the antenna I have in wamart not too long ago, so my brother bought one and I bolted it to the side of his house, (he is my neighbor) he gets the same scan i get, but he likes tv even less than my wife so, he only watches football.
There absolutely is such a thing as an hd tv antenna and they wirk great!
2016 Shamrock 23WS
2018 F150 Ecoboost
Mainframe is offline   Reply With Quote
Old 03-09-2017, 03:28 PM   #6
No, there is not. You just happen to have bought a well-designed antenna.
johntaylor is offline   Reply With Quote
Old 03-13-2017, 06:38 PM   #7
I put the rabbit ears off a TV we bought in 1989 on our new LCD flat screen and they pull in the over the air digital TV signal just fine. The big difference in analog to digital signals is the digital is kind of all or nothing. So while you might have pulled in an old weak analog signal with some snow that you considered watchable, the new digital signal won't come in at all. Then when it does come in it's beautiful crystal clear.
Hersbird is offline   Reply With Quote
Old 03-13-2017, 07:37 PM   #8
Basically, if it's a flat screen you have a digital reciever. If a tube tv, you have an analog receiver and will need a digital converter box.
Chunk6649 is offline   Reply With Quote
Old 03-13-2017, 09:07 PM   #9
Basically, but the antenna on the roof is the same on a 1955 model or a 2017 model, and antenna is an antenna. Buy a new flat panel TV to put inside and it will have all the necessary digital receivers built in. If the camper still has a big honking tube TV in it, it's time to ditch it anyway.
Old 04-03-2017, 02:30 PM   #10
Thanks for all the reply's. I have put a newer HD tv in and the PIC is great! just waiting a few more weeks till time to de-winterize and take out on it's maiden voyage! Thanks again and I am sure I will be asking a bunch more questions.
23ss
