Old 06-23-2017, 07:15 AM   #1
Lawlesszoo's Avatar
No water coming into toilet
Fourth trip out this season, got set up, pushed step on toilet to start water and got a big gush of air and water then a trickle of water.
Water is flowing fine through all faucets but hardly a thing to toilet. No leaks can been seen yet. Haven't crawled under camper yet but no wet spots on the ground.
This is a 2016 Roo 21SS, has anyone else had this? Don't know where to start looking.
Lawlesszoo is offline   Reply With Quote
Old 06-23-2017, 07:20 AM   #2
Mr. Dan's Avatar
The last time I saw that here, the culprit was trash in the water valve behind the toilet.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 06-23-2017, 07:25 AM   #3
2017 Windjammer 3029w
Another warning. A neighbor had the valve or on his toulet fail open some. They went away for a little while only to find water running out the trailer door. His new trailer was condemmed after that because of the amount of sewer water and mold started forming before any repairs could be started. Luckily his insurance gave him value.
Dastagg is offline   Reply With Quote
Old 06-23-2017, 07:25 AM   #4
Somewhat common issue discussed here many times.
Here is one such discussion.
Toilet Valve
You are going to have to clean the valve at the toilet.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 06-23-2017, 08:02 AM   #5
Lawlesszoo's Avatar
Thanks all. I know what I will be doing later!
Old 06-23-2017, 08:17 AM   #6
On newer Dometic units you can turn off the water pressure and remove the valve by depressing two small plastic finger latched that hold it in the unit and clean it out. On my unit it takes a couple of minutes once you know where to press.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 06-23-2017, 08:22 AM   #7
Lawlesszoo's Avatar
Thanks! All my years of camping I've never had to do this. All the help yall give will be useful!
Old 06-23-2017, 08:40 AM   #8
Flybob's Avatar
Opening the two low point drains with water in the water heater is the usual cause of this problem. As the water system drains the water in the WH drains out of the cold water feed ( low point in the WH) taking some of the crud from the bottom of the tank with it. Some of the crud can remain in the cold water line as the system nears empty. The next time you charge up the water system for use, the crud is pushed along to until it reaches a valve or faucet strainer where it will partially or completely stop the water flow. To reduce the probability of this happening, drain the WH before opening the low point drains.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-23-2017, 08:59 AM   #9
this is great info to know
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 06-24-2017, 09:07 AM   #10
Wolverine 1945's Avatar
A very good reason to turn the pump off if your are leaving !!!
We never leave the pump on in our MH if we are not going to be right there !!!
We also turn our well pump off if we are going away for a couple of days or more !!! I could tell you some stories that would make you sick about flooded homes,,, because people did not flip the breaker off on there well pumps !!!
Wolverine 1945 is offline   Reply With Quote
water
