Old 07-25-2017, 06:36 PM   #1
palomino leaking
can anyone please tell me how they solved this problem. On one of the bunk pulldowns water runs down the side and pools on the bottom and ends out running inside the camper, i can see no fix for this and
is a very poor design.
Anyone having the same problem? this is a Palomino hybrid and I see no way to do this.
HELP!
lrhm is offline   Reply With Quote
Old 07-26-2017, 06:47 AM   #2
RooBert's Avatar
I found a leak like this on my old 190x. The caulking around the latch was the issue. I removed the latch added caulk to the screw holes, laid down a bead around the perimeter of the latch. Screwed it back in and then caulked the edges again.
I poured a cup of water around the bunk end seals until I pin pointed the latch.
RooBert is offline   Reply With Quote
Old 08-17-2017, 08:44 AM   #3
Send a message via AIM to eprovenzano Send a message via MSN to eprovenzano
I have a Palomino as well... I've never had a leak. Can you post a few pics, we should be able to help you.
2013 Palomino Stampede 23S HTT
2015 Dodge Ram 1500 6" lift rolling on 35's
eprovenzano is offline   Reply With Quote
leak, palomino
