Old 01-06-2016, 03:48 PM   #21
I didn't have time to post all the Andersen issues earlier, but I split the fiction material liner that surrounds the ball. Andersen sent me a replacement liner under warranty (They said the chains were to tight but remember they told me to get chains tighter). There is a video on how to replace the liner. No where near as easy as they make it appear. Never was able to change liner, it needed to be pressed out and back in. There was also sufficient amount of wear on the ball, so would imagine there is wear inside the hitch itself just can't see it.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 01-06-2016, 03:58 PM   #22
The new washers and shorter springs make tightening a non-issue. You can really crank on them now, but there is still a spring compression limit.
The lining material has also changed. The old material was wearing out too quickly and when dirt/dust got in there it started making noise. Silence was one of my purchase requirements. My liner (and ball) came out just as easy as the video showed. It didn't go back in as easily. That took a long trip to reset where the C clip would go back on. There was 0 wear inside the hitch other than the lining.
I am still not sure I would go the Andersen route with an 11K TW, though. I think I would just get a 5er
Ball before cleanup
Ball after cleanup
Name:	ball cone cleaned up.jpg
Ball housing before cleanup
Name:	inside cone 1.jpg
Ball housing after cleanup
Name:	inside cone 2.jpg
Old anti-sway (liner) material
Name:	inside red material  2.jpg
New (left) Springs and washer vs Old (right)
Name:	Old vs New.jpg
madmaxmutt is offline   Reply With Quote
Old 01-06-2016, 04:40 PM   #23
Good to know they are making improvements.
Hensley Arrow
Old 01-06-2016, 04:55 PM   #24
Thanks for the info on the updated Andersen parts madmaxmutt. I did not know about. Not having issues with my 3 year old setup but think I'll contact them for the new parts anyway.
Mikewcrook is offline   Reply With Quote
Old 01-06-2016, 06:25 PM   #25
We put 11k miles on it this year. I started seeing the noise symptom after about 8k IIRC.
Sent from my XT1254 using Tapatalk
Old 01-06-2016, 06:38 PM   #26
Thanks again. I estimate I have about 12000 on mine in the last 2 years. No noise but I'll take the ball out and check the lining to be sure.
Old 01-09-2016, 08:18 AM   #27
yetavon's Avatar
Reese dual cam here and love it. Rock solid feel driving down the road beside a big rig.
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 01-09-2016, 08:55 AM   #28
Might want to think twice about a Camco hitch...
RV Quick Tips: RVer's trial by fire yields good advice for all of usRV Quick Tips: RVer's trial by fire yields good advice for all of us
Rbertalotto is offline   Reply With Quote
Old 01-09-2016, 09:21 AM   #29
Originally Posted by Rbertalotto View Post
Might also NOTE that the Brake Safety Pin was NOT Pulled because of the length and way it was connected! Youroo!!
youroo is online now   Reply With Quote
Old 01-09-2016, 09:29 AM   #30
Wayne Joan's Avatar
I pulled a 27 ft. TT for a couple of years with an Andersen. Found the Andersen to be by far the best hitch I have used. I would still be using the Andersen but, we went to a 5er.
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017
86 days camping 2018
Wayne Joan is offline   Reply With Quote
hitch, select
