Old 03-15-2018, 10:44 AM   #1
Roo 23ss Bathroom Skylight
So quick question. I have a 2008 23ss. I purchased this in excellent condition about a year ago. The previous owner at some point had removed the skylight in the bathroom and placed a piece of reflectant space blanket in there to aid in the climate control in the camper. The problem is that it makes the bathroom very dark even with the lights on. I want to remove the skylight cap from the outside, but have never done such. The cap is very well sealed with self leveling sealant. My question is how difficult is this to get off? and is there anything I should be concerned with in regards to protecting the roof while removing the sealant? I do not see any other way I can get into the skylight
Thanks for your help
fvrs7189 is offline   Reply With Quote
Old 03-15-2018, 11:09 AM   #2
I'm not 100% but I thought my bath skylight had a removable panel from the underside. Might take a look.
m
2014 Flagstaff Shamrock 21SS
2011 F-150 Crewcab ECO-BOOST Lariat 4x4
Fire Battalion Chief-09-11-2026 retirement!!!
mfeeley is offline   Reply With Quote
Old 03-15-2018, 11:53 AM   #3
Thanks. I will double check. First looks I did not see any screws, etc to remove the inside portion
Old 03-15-2018, 12:31 PM   #4
bikendan's Avatar
Are you talking about the shower skylight?
Equalizer WDH
Old 03-15-2018, 02:22 PM   #5
Yes
Old 03-16-2018, 01:59 PM   #6
It may be a window tint which has an adhesive. the way we remove them at work is with a steamer and a heat gun, or a hair drier. Check an edge and try to slowly peel it away while warming it with a hair dryer.
TTED is offline   Reply With Quote
Old 03-16-2018, 06:39 PM   #7
Velosprout's Avatar
There is an inner plastic cone in the skylight above the shower. It is held on to the ceiling with white screws, probably about 6 or 8 total, which use a square drive screwdriver. Have a vacuum ready, as some foam debris, insects, etc., will fall into the shower and bathroom. Be careful with the inner skylight cone; it is very thin, delicate, and brittle molded plastic. A replacement unit runs $48 to $140 depending on where you buy it.
You should be able to remove the inner skylight unit, remove the reflective insulation, and replace. You may want to, as I have done, put the reflective insulation cut to fit just around the exterior of the white plastic cone where it is not visable. Affix with strong duct tape so it won't bounce up into your view when you hit bumps in the road.
Do not break the seal or remove the outer skylight. However, double check the dicor lap sealant to make sure there are no cracks developing, and if necessary clean and apply more dicor self-leveling lap sealant.
The upper skylight is supposed to be clear, but gets cloudy with age and sunshine. It can be brought back to new condition on the exterior with an electric drill with a soft buffer (or headlight-kit polisher) and Meguiar's Plastic-X clear plastic cleaner/polish. Regular treatment with the Plastic-X and a micro-fiber towel should keep it clear and new looking.
Good look with your project.
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
Velosprout is offline   Reply With Quote
Old 03-16-2018, 10:32 PM   #8
Velosprout's Avatar
http://www.campingworld.com/skylight...SABEgJiYPD_BwE
Here is a link to the part.
Velosprout
Old 03-17-2018, 05:31 AM   #9
It is not a window film. I see the actual texture of the reflective insulation sitting in the layer between inside membrane and outside
I will look for those screws. Ill let you know what I find.
Old 03-17-2018, 06:02 AM   #10
bareftn's Avatar
how about a pic?
bareftn is offline   Reply With Quote
23ss, bathroom, light, roo, skylight
