Old 05-21-2017, 09:57 AM   #1
cheeseheadjim's Avatar
Season 2 Episode 1
Finally got the 2017 camping season underway. Rainy and chilly all day yesterday so I used the time to change out all of the interior ceiling lights with lights that have a switch in the center. That way we can turn on only as much as we want. Having all 8 on is a bit too bright.
I also changed out the thermostat with a digital one.
I see the sun poking through now so we can get outside today.
Jim SClick image for larger version
2018 Flagstaff 25FKS
2015 Ram 1500
cheeseheadjim is offline   Reply With Quote
Old 05-21-2017, 10:04 AM   #2
Here are pics of the old lights; new lights; and thermostat Click image for larger version
ID:	138615Click image for larger version
ID:	138616Click image for larger version
2015 Ram 1500
Old 06-20-2017, 11:05 PM   #3
Originally Posted by cheeseheadjim View Post
Here are pics of the old lights; new lights; and thermostat Attachment 138615Attachment 138616Attachment 138617
Great idea on the light swap and the thermostat replacement! Can you provide a link where you purchased both?
Much appreciated
Bgncypress
bgncypress is offline   Reply With Quote
Old 06-21-2017, 06:10 PM   #4
Here is link to the lights:
https://www.bonanza.com/listings/10-...m_source=email
Here is link to thermostat:
https://www.amazon.com/gp/r.html?C=2...XCJDQCPKKIL8OA
2015 Ram 1500
Old 06-21-2017, 06:36 PM   #5
Jim,
Great thanks for the quick response!
Old 06-23-2017, 04:54 PM   #6
Cheeseheadjim,
A couple more questions when you get the time. Could find the info on the web site.
1). Will the existing screws work on the new lights?
2). Are the new lights the same size as the existing lights?
Thanks again,
Bgncypress
Old 06-24-2017, 08:35 AM   #7
Originally Posted by bgncypress View Post
Cheeseheadjim,
Thanks again,
Bgncypress
Howdy bgncypress !
Yup- the existing screws fit the new lights.
The new lights are four inch diameter like the existing lights. They are the same thickness too. So they look like the existing lights when you install them.
The only thing I had to do was drill new mounting holes. This was because the new lights had a slightly different mounting hole pattern. They use the same screws but in slightly different locations.
I had originally planned to only replace half of the lights but then I found the ten pack of lights for $40 so I decided to swap all of them. I even have a couple of spares. Of course I kept all the old ones too so I really have lots of spares now.
Jim S
2015 Ram 1500
Old 06-24-2017, 09:24 AM   #8
Howdy bgncypress !
Jim S
Jim, Thanks for confirming! Sounds like a good deal, appreciate your feedback.
Have fun camping!
Old 06-29-2017, 09:01 PM   #9
RooBert's Avatar
Was the thermostat a direct swap? My solaire had a digital one and it was great. My 2017 IKSS really should have one.
RooBert is offline   Reply With Quote
Old 06-30-2017, 01:03 PM   #10
Hey Roobert !
If you are asking if the wiring colors are the same between the new and old thermostats, I think that they are, but I really don't remember. There may have one or two that were different.
I just made a table that listed the thermostat function (like 12V negative or fan on...) for both the new and the old units (this info is on the datasheet for each unit). For each function, I then listed, for each function, the color of existing thermostat wire, and the color of the new thermostat wire. Then I swapped each trailer wire (one wire at a time) from the old thermostat wire to the new thermostat wire, being sure that the function were kept the same.
I hope this is clear.
Jim S
2015 Ram 1500
Old 06-30-2017, 02:48 PM   #11
Restcure's Avatar
Nice mods!
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 07-03-2017, 12:20 AM   #12
Jim SAttachment 138614
I see you have some Awning tie downs installed. Was this a kit? Are the poles to the ground removable and set up each time? How do the attack up top?
I also noticed that you have one side of the awning real low, does it hit the slide like mine does if I go that low? If it does have you had any problem with it?
Thanks.
Roo-minator is offline   Reply With Quote
Old 07-03-2017, 06:29 AM   #13
AquaMan's Avatar
Contact Turbs for awning poles. Pretty much a bolt on installation.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 07-04-2017, 11:29 AM   #14
Roo-minator,
The awning poles were a kit I bought from a fellow forest river forum member. His name is Turbs, so you can get ahold of him for details. The poles are bolted to the awning frame, and are easily bolted on. They remain on once installed, and fold up for travel or when not in use. They are quality made out of powder coated aluminum.
The awning does contact the slide when it is deployed, but since it is anchored with poles and tie-downs, it does not have constant movement, it simply lays on the slide, so it doesn't wear.
Jim S.
2015 Ram 1500
Old 07-04-2017, 01:12 PM   #15
Roo-minator,
Jim S.
Thank you for the info. I like them and will add them to the RV wishlist.
