Old 04-04-2011, 10:10 PM   #1
Smokyroo's Avatar
Shaky Roo...what to doo
Hi Yall:
We are camping in the roo and we love the space. However, this is our 3rd camper and by far the shakiest. When my teenage daughter and her friend move on the front bunk...the entire thing moves. I have both wheels choked or chucked or however it is spelled on both sides front and rear. The stabilizers are down and tight. Any and all ideas welcome here...
Signed Shaky Roo in Paradise....
PS that stupid carbon monoxide/lp gas detector goes off even though the gas is off and not in use...I am thinking of getting my wire cutters and making a mod.....
Bob, Tonya and the kids
11 Rockwood Roo 233S
08 Grady White Seafarer 228
08 Tundra 5.7 liter 4x4 crew cab TRD limited
08 Toyota limited 4 Runner Iforce V8 full time 4WD, tow package
Smokyroo is offline   Reply With Quote
Old 04-04-2011, 10:21 PM   #2
sherdep's Avatar
Hey Bob
Funny as it sounds to cut the carbon monoxide / LP gas detector - maybe you have a faulty detector or possibly a leak somewhere and it really isnt faulty - maybe try reseting the breaker to it or push the test button or blow into the sensor to try and clear it out
Maybe try putting a 2x6 under each feet/ foot of the leveling jacks so they are not so extended out - I read somewhere that if the scissor jack is extended way out it will not help with the stability of the trailer.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-04-2011, 10:40 PM   #3
bikendan's Avatar
Bob, do you just have the wedge chocks on the wheels or do you have a tandem wheel chock?
you really need tandem wheel chocks on both sides, along with the stabs down. the plastic wedge chocks aren't going to prevent movement like tandems.
are you sure your battery is good? normally the detector goes off when the battery is low.
Old 04-04-2011, 10:56 PM   #4
The detector will also go off with certain hair sprays, deodorants, air fresheners, etc. It will go off when the 12 volt battery is low, but will be rhythmic beep. Since you mentioned front bunk, do you still have the tongue jack gown and tight?
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-04-2011, 11:31 PM   #5
miatared's Avatar
I had the same issue on my '11 Shamrock and called MTI Industries in Volo, IL - the makers of the combo alarm, CO2 and LPG, they had a bad batch of models last year and they sent me a brand new one.
Probably worth a phone call.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 04-05-2011, 06:18 AM   #6
yvesm's Avatar
Hi Yall:
Get the Steady Fast system SteadyFast: 5th Wheel and RV Travel Trailer Stabilizer System
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 04-05-2011, 08:05 AM   #7
Wanna Be Camper
SaskCampers's Avatar
Do you have X-Chocks between both wheel sets?
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-05-2011, 08:24 AM   #8
(Kim)
Labzy's Avatar
Hi Yall:
Very sorry about your 'wobble' but I dont know enough about that to give any advice.
I do however want to veer you away from your impulse to dis-connect the detectors.
Please dont do that.....years ago a close friend of ours rented RV's (2 of them) for a bunch of guys, 4 men from the second trailer died.
The detector's had not gone off to warn them.
It still freeks me out when I think about it.
I will be adding a back-up battery powered detector just to always be on the safe side.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 04-05-2011, 09:26 AM   #9
Smokyroo's Avatar
Thanks Guys....I don't have X choks...I think y'all are right on there. We just have the plastic ones on wheels...fore and aft. We are at a state park with shore power...but the detector only went off yesterday morning...been quiet since then.
Old 04-05-2011, 09:38 AM   #10
Wanna Be Camper
The X-Chocks will probably eliminate 90% or more of your wobble.
John & Deb
