Old 08-12-2017, 07:07 AM   #1
Lawlesszoo's Avatar
Slide maintenance
I see several discussions on stuck or broke slides here. I know that is probably one if my biggest fears while camping.
Does anyone have useful links on the maintenance of slides? I haven't searched hard for this information yet but I'm sure it's something that should be checked regularly.
Lawlesszoo is offline   Reply With Quote
Old 08-12-2017, 12:22 PM   #2
bikendan's Avatar
Other than a blown slideout 30 amp fuse, I never had an issue.
I used slideout lube all the time and kept the seals cleaned and conditioned.
It had a manual crank if the electric motor failed.
Old 08-14-2017, 10:05 AM   #3
Consider a slide topper. It covers the slide and keeps debris from jamming the slide or damaging the top seal.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 08-14-2017, 10:39 AM   #4
Lawlesszoo's Avatar
Thanks all. We do have a topper and watch the seals and all that, I guess I'm just over thinking what other maintenance it may need.
Old 08-14-2017, 10:50 AM   #5
Send a message via AIM to eprovenzano Send a message via MSN to eprovenzano
Same here... I have a topper over the slide, but I need to get some dry lube for the mechanisms and do some much needed maintenance.
I don't know it it's just me, but in the back of my mind, knowing I haven't lubed the slide drive, it seems slow... I'm sure its just me, but I'll lube it up just for piece of mind...
2013 Palomino Stampede 23S HTT
2015 Dodge Ram 1500 6" lift rolling on 35's
eprovenzano is offline   Reply With Quote
Old 08-15-2017, 10:55 AM   #6
I have a IKSS and the dinette slide is getting a bit squeaky when going in and out. Anyone know what the mechanism looks like and which lube to use?
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
wharfrat48 is offline   Reply With Quote
Old 08-15-2017, 11:09 AM   #7
I haven't crawled under the open slide to have a look yet... but from what I've gathered, we need to use a dry lube, I've seen many different suggestions, but I think I'm going to go with CRC Power Lube with PTFE
Old 08-15-2017, 01:55 PM   #8
bikendan's Avatar
As I mentioned in post #2, a slideout lube is best.
It's a dry lube and various companies have them.
Got mine at Wal-Mart.
Old 08-17-2017, 08:32 AM   #9
I lubed up the tracks /runners a little last night... I then ran it in and out a few times... maybe it's my imagination, but to me it seems to slide in easier... Oh well, I'm glad I did this and will add it to the annual maintenance schedule
maintenance, slide
