Old 08-04-2013, 12:15 PM   #11
Triguy's Avatar
Originally Posted by myfirstroo21ss View Post
It is a 2010 im not sure if that makes a difference. I am not seeing anything between the tires.
I have a 233S and mine is located on the slide side (driver's side of the trailer).
It is no longer blowing fuses but its like its not catching and it just spins.
Dave I did try that with no luck. At first there was a little movement but now there is no ratcheting and it sounds like it is just spinning. I can't find any bolt to manually do it. I've looked between the tires but I must be blind! Thanks for the help
Sounds to me like the hairpin (cotter pin) might have sheared off. I can post a picture of what It looks like. This will be located on the hex head that you manually crank.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-04-2013, 12:19 PM   #12
Truth B Towed's Avatar
someone else had same issues "Slide out motor has failed 3 times. The motor keeps either stripping gears or simplly will no longer move the slide. We have to crawl under and crank it with a wrench" s Triguy said cotter pin was other problem.
2008 Silverado 5.3 tow package
2013 Roo 25rs
2014 nites booked 10
Truth B Towed is offline   Reply With Quote
Old 08-04-2013, 12:25 PM   #13
myfirstroo21ss's Avatar
Thanks a pic would be helpful.
myfirstroo21ss is offline   Reply With Quote
Old 08-04-2013, 12:36 PM   #14
Triguy's Avatar
Here you go. I hope that this helps you. I am looking from my slide-side (see the adjustment bolt for perspective). Remember, though, mine is a 233S so we might have different Lippert components or arrangement. Either way, you should have a pin.
ID:	36885   Click image for larger version
ID:	36886   Click image for larger version
ID:	36887   Click image for larger version
Scott
2012 Shamrock 233S
Old 08-04-2013, 01:05 PM   #15
Mine looks similar but I do not see any hole in frame with bolt. Do I just use a wrench on the square rod?
ID:	36889   Click image for larger version
ID:	36890   Click image for larger version
ID:	36891   Click image for larger version
Old 08-04-2013, 01:15 PM   #16
Found this....
Anyone out there have a Roo?
Silverado HD 2500 6.0 Crew Cab
2014 Roo 21ss
sdelam is offline   Reply With Quote
Old 08-04-2013, 01:24 PM   #17
Triguy's Avatar
I honestly do not know. The motors and mounting look different. I would hesitate to turn the rod that way.
Scott
2012 Shamrock 233S
Old 08-04-2013, 01:35 PM   #18
Thanks Triguy
Old 08-04-2013, 01:37 PM   #19
Dave_Monica's Avatar
Could you have someone bump the drive control while you're under there and is where the slipping/spinning noise is coming from...ie gearbox, motor?
Dave
Old 08-04-2013, 01:52 PM   #20
Triguy's Avatar
Thanks Triguy
Sorry it didn't work for you. Hard to believe that there is no manual override extending from the gear box. Weird...
Scott
2012 Shamrock 233S
