Old 08-04-2013, 10:10 AM   #1
myfirstroo21ss's Avatar
Slide wont work on 21ss
I'm having an issue with my slide on my 21ss. I keep blowing fuses and it won't come in. Can anyone tell me how to manually crank it in? I can't find it anywhere.
myfirstroo21ss is offline   Reply With Quote
Old 08-04-2013, 10:54 AM   #2
sdelam's Avatar
There is a hole between the tires on the door side of the trailer for the handle.
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
sdelam is offline   Reply With Quote
Old 08-04-2013, 11:03 AM   #3
Dave_Monica's Avatar
If it's continually blowing fuses, the slide room may be binding (can you see any evidence of that?) or you have a lot of extra weight in the slide room.
Dave
Old 08-04-2013, 11:07 AM   #4
It is a 2010 im not sure if that makes a difference. I am not seeing anything between the tires.
Old 08-04-2013, 11:12 AM   #5
sdelam's Avatar
On mine at least, it is in the brown part of the fender. The handle fits over a T shaped protrusion on the frame
Old 08-04-2013, 11:22 AM   #6
It is no longer blowing fuses but its like its not catching and it just spins.
Old 08-04-2013, 11:27 AM   #7
On the door side?
Old 08-04-2013, 11:53 AM   #8
Is it making a ratcheting sound like when it's fully in or out? Have you tried having someone outside pushing on the slide while pushing the in button?
Dave
Old 08-04-2013, 12:00 PM   #9
Dave I did try that with no luck. At first there was a little movement but now there is no ratcheting and it sounds like it is just spinning. I can't find any bolt to manually do it. I've looked between the tires but I must be blind! Thanks for the help
Old 08-04-2013, 12:12 PM   #10
Truth B Towed's Avatar
I found this on your 21ss '"There is indeed a hex bolt on the motor, but the axle is in the way and makes cranking a difficult operation"
2008 Silverado 5.3 tow package
2013 Roo 25rs
2014 nites booked 10
Truth B Towed is offline   Reply With Quote
Old 08-04-2013, 12:15 PM   #11
Triguy's Avatar
I have a 233S and mine is located on the slide side (driver's side of the trailer).
Sounds to me like the hairpin (cotter pin) might have sheared off. I can post a picture of what It looks like. This will be located on the hex head that you manually crank.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-04-2013, 12:19 PM   #12
someone else had same issues "Slide out motor has failed 3 times. The motor keeps either stripping gears or simplly will no longer move the slide. We have to crawl under and crank it with a wrench" s Triguy said cotter pin was other problem.
2013 Roo 25rs
Old 08-04-2013, 12:25 PM   #13
Thanks a pic would be helpful.
Old 08-04-2013, 12:36 PM   #14
Triguy's Avatar
Here you go. I hope that this helps you. I am looking from my slide-side (see the adjustment bolt for perspective). Remember, though, mine is a 233S so we might have different Lippert components or arrangement. Either way, you should have a pin.
ID:	36885   Click image for larger version
ID:	36886   Click image for larger version
ID:	36887   Click image for larger version
Scott
2012 Shamrock 233S
Old 08-04-2013, 01:05 PM   #15
Mine looks similar but I do not see any hole in frame with bolt. Do I just use a wrench on the square rod?
ID:	36889   Click image for larger version
ID:	36890   Click image for larger version
ID:	36891   Click image for larger version
Old 08-04-2013, 01:15 PM   #16
sdelam's Avatar
Found this....
http://www.forestriverforums.com/for...oo-7034-2.html
Old 08-04-2013, 01:24 PM   #17
Triguy's Avatar
I honestly do not know. The motors and mounting look different. I would hesitate to turn the rod that way.
Scott
2012 Shamrock 233S
Old 08-04-2013, 01:35 PM   #18
Thanks Triguy
Old 08-04-2013, 01:37 PM   #19
Could you have someone bump the drive control while you're under there and is where the slipping/spinning noise is coming from...ie gearbox, motor?
Dave
Old 08-04-2013, 01:52 PM   #20
Triguy's Avatar
Thanks Triguy
Sorry it didn't work for you. Hard to believe that there is no manual override extending from the gear box. Weird...
Scott
2012 Shamrock 233S
