Old 07-17-2015, 05:04 AM   #1
bpa098's Avatar
Toilet water running
Well we're on another 4 day trip with family. Still getting settled into our 15 solaire 213x. Set up around 3pm yesterday and by late evening I noticed the black tank level was getting high. We never come close to filling the black tank, grey tank yes but not the black. Thankfully this camp ground has a honey wagon since I set up in a tricky spot and would hate to pack up and go to the dump station. Ok so why is this? I know last weekend I let my brother borrow my camper for 1 night, but he hardy used the bathroom, gauge didn't even register anything.
So while using the toilet I notice water is trickling out as though someone was pushing the pedal a little to put water in the bowl. This is my first trip with water hook up. Pressure regulator on the camp hook up and I put mine on too. Temporary solution was I turned off the water valve. As I was several cold ones into the evening and enjoying R&R I left it be but want to diagnose today.
Any suggestions or thoughts?
bpa098 is offline   Reply With Quote
Old 07-17-2015, 05:18 AM   #2
SYE
SYE's Avatar
If it was like thew flush valve was pressed, the bowl would fill up and eventually overflow, I am not familiar with the type of camper but many have a control panel with a bunch of switches and you black tank flush might not be closed all the way, just a thought remember I said I am not familiar with your type of camper.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 07-17-2015, 05:26 AM   #3
bpa098's Avatar
It was like a slight trickle so with enough people using it I don't think it ever had time to fill up, just each flush was more water than normal.
My black flush is a separate hook up out side. To my knowledge there is no way to flush the tank with my main water system
Old 07-17-2015, 05:32 AM   #4
SYE
SYE's Avatar
OK, It was just a thought
Scott & Vicki
2021 4 reserved
Old 07-17-2015, 06:15 AM   #5
The toilet would have to be full of water in order to fill a 30 gallon tank in a few hours. even if the bowl held 2 gallons it would take 15 flushes, and you would definitely notice if it was that full. Before if you had water in the bowl did it stay or did it slowly drain? I suspect your toilet is 1: not sealing properly and 2: you have a flush valve that is stuck open a little. The valve can stick open if a piece of debris get stuck in it. You will have to remove the valve and inspect for whats wrong. Should be able to find instructions on line to remove valve.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 07-17-2015, 06:39 AM   #6
Herk7769's Avatar
I had the opposite problem; debris in the valve stopped all water flow.
I DID get good photos of the valve though, maybe they will help you troubleshoot:
While I had it out, I added a washdown wand to save water during cleanup.
I tried using the existing hose barb (don't forget to cut the tip off), but the pressure was reduced so much I did not get the cleaning I was looking for.
You could also add a hose connection for a black tank wand if you don't have a tuboflush to avoid routing a long hose through the window or door like I used to do with our travel trailer.
Name:	Camper Bidet 018.jpg
ID:	83146   Click image for larger version
Name:	Camper Bidet 022.jpg
ID:	83147   Click image for larger version
Name:	Camper Bidet 030.jpg
ID:	83148   Click image for larger version
Name:	Camper Bidet 017.jpg
ID:	83149   Click image for larger version
Name:	Camper Bidet 035.jpg
Name:	Camper Bidet 038.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-17-2015, 06:40 AM   #7
Herk7769's Avatar
A sticking flush valve linkage could leave the door open just enough to allow seepage and still leave enough water to "appear" normal.
Old 07-17-2015, 06:50 AM   #8
bpa098's Avatar
Thanks for the info. Family still sleeping. Will check it out later today
Old 07-17-2015, 11:17 AM   #9
bpa098's Avatar
Hum doesn't seem to be leaking today. Honey wagon come in a bit
Old 07-20-2015, 08:12 AM   #10
bpa098's Avatar
Just thought i would do an update. I monitored for the next few days, back at work now
Seems as though after flushing the toilet or putting a little water in the bowl, once the valve closes there is a little water left to trickle out of the holes. It stops in a minute. Kind of like turning off my house shower, the water left in the shower head trickles out for a moment.
As for my black tank filling up so fast, starting to believe something was stuck on the float. The honey wagon guys pumped me out when i wasnt there, but my gauge still said it was 1/3 full. I saw them later and they said hardly anything came out. Oh well $15 was worth sleeping at night not worried about an overflow. Yesterday we were back up to 2/3 full before packing up. Being a nice guy, i moved my camper to another site as my brother, sister in law and kids were coming for a 3 day stay and borrowing my rig (my rental fee, i left one of my kids with them LOL). we stayed till late evening with them and i told him all about the tank deal and that he might want to get pumped out again. I go in to show him the gauges, hummmm its reading 1/3 again. All i can figure, moving the camper stirred the contents and maybe washed some paper off the float.
Will check in with him, test at home and in less than two weeks my better half and I are sneaking away for a no kids or pets weekend trip to Keuka state park. gotta check out some hiking in Watkins Glen and Letchworth then maybe a winery tour.
Old 07-20-2015, 12:20 PM   #11
bikendan's Avatar
There is no tank sensor "float", if that's what you're thinking.
Just probes on the side of the tank.
Old 07-20-2015, 12:22 PM   #12
bpa098's Avatar
wasnt sure how that worked, but am i possibly right in saying something in there was messing with the sensor?
Old 07-20-2015, 12:29 PM   #13
bikendan's Avatar
SURE!
Most don't even rely on the erratic tank sensors.
They are famous for their unreliability.
TP or poo get on them and they show full when it's not.
Old 07-20-2015, 12:33 PM   #14
bpa098's Avatar
just read a few other old post and i see how the sensors work now. So I am pretty sure, driving to the campground with a little matter in the tank threw off the sensor. Then moving it again with stuff in there fixed the issue this time.
similar to my post a few weeks back, i like these minor issues, i keep learning more and more about these modern units.
Old 07-20-2015, 12:39 PM   #15
Flybob's Avatar
The sensors are essentially just four screws attached to the tank at the various fluid levels. When the liquid in the tank touches the bottom screw and one of the upper screws, that light lights. If a piece of TP or just general sludge on the wall of the tank touches the two screws, it registers, Your gut feel is generally much more reliable than the sensors.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-20-2015, 01:07 PM   #16
bpa098's Avatar
Got it thanks. i guess before any travel it should be flushed out good. Previously i didnt think a few bathroom breaks would have affected much and clean out at home is a bit of a pain.
thanks for all the info folks
water
