Old 09-29-2006, 11:59 AM   #1
Towing your Roo
Hi All,
I'm looking at a Rockwood Roo 21SS. I want to tow it with a Chevy Astro 4.3 6 cyl. Is this do-able?
Kelly
cameronbeardies is offline   Reply With Quote
Old 09-29-2006, 09:39 PM   #2
MRimmer's Avatar
My first TT was 4350 dry and we pulled it with a S-10 4.3 with a 3.42 gear locally. It felt ok, but you should be even better. I hear the Astro has the true 1/2 ton truck brakes and rear axle.
What gear do you have?
Specs on the trailer you mentioned as follows
Dry Weight 3288lbs (1491 kg)
GVWR 4719lbs (2141 kg)
Cargo Capacity N/A
Hitch Weight 319lbs (145 kg)
Axle Weight 2969lbs (1347 kg)
Exterior Height 9.33' (2.84 m)
Exterior Length 21.75' (6.63 m)
Exterior Width 7.50' (2.29 m)
Interior Height 6.50' (1.98 m)
Fresh Water
Gray Water
Black Water 31gal (117.3 L)
25gal (94.6 L)
25gal (94.6 L)
Awning Size N/A
MRimmer is offline   Reply With Quote
Old 09-30-2006, 10:47 PM   #3
Screamin' Eagle's Avatar
Cool cameronbeardies
Welcome to Forest River Forums!!!!!!
1977 Pontiac Trans AM ***32K/Original Miles***
2003 Chevy 3500 Crew Cab 4X4 Duramax Diesel
2006 Harley Davidson FLHTCUSE
2007 Chevrolet Suburban LTZ 4X4
MRimmer says that I need a Toy Hauler......
Screamin' Eagle is offline   Reply With Quote
Old 10-02-2006, 02:29 PM   #4
Astro/Safari towing Roo
Thanks for your help. I just bought a Safari with the towing package and it is geared 3.73. Now the questions about hitches will start
Kelly
Old 10-02-2006, 04:11 PM   #5
MRimmer's Avatar
I use the "equal-i-zer" and I love it
Bought mine here
http://www.rvwholesalers.com/catalog...8&cat=0&page=1
Old 10-02-2006, 04:51 PM   #6
milzat's Avatar
I can attest to the Equal-i-zer WD hitch. For the price, you can't beat the quality and performance.
milzat is offline   Reply With Quote
Old 10-03-2006, 07:13 AM   #7
Thanks for the advice and the URL. I found a dealer here in Hamilton Ontario.
Kelly
Old 10-19-2006, 08:01 AM   #8
Packing the Tow vehicle
OK, more questions about towing. Bear in mind I've been driving a C-Class motorhome the last 15 years, and loading wasn't an issue.
When I load the van (Safari), I keep the heavy weight off the very back? and the weight off of the hitch area in the front of the trailer? I travel with 4-6 Bearded Collie dogs and will have dog show paraphenalia. Would it be better to put some weight in a roof top carrier?
Thanx,
Kelly
Old 11-27-2006, 08:43 PM   #9
21ss
I have a 21SS(07) and have towed it with a Dakota 3.9 V6.
Equalizer is a MUST as it sway control.
We now tow it with a crew cab Silverado (Dakota died after 209k miles).
Good luck with the trailer.
We love ours .
21ss is offline   Reply With Quote
Old 08-21-2010, 04:31 PM   #10
jerr7's Avatar
Send a message via AIM to jerr7
equal- lizer
Roo 23ss 2009
Chevy Silverado 1500 X cab Blk,5.3 V8 3.73
Equalizer Hitch,Garmin GPS,Prodigy Brake Controller
http://community.webshots.com/user/j...host=community
jerr7 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fifth Wheel Towing rubysamm General Travel Trailer & Fifth Wheel Discussion 9 03-21-2007 09:22 PM
What are you towing behind your motorhome? ghamblen Towing, Tow Vehicles, Hitches & Toads 6 02-08-2007 04:30 AM
Whatcha think? WWTT29FKSS Towing, Tow Vehicles, Hitches & Toads 7 08-27-2006 06:54 PM
