Old 05-30-2016, 03:00 PM   #1
TV Sound through RV Speakers
I have a 2013 Rockwood Roo. Is there a way to get the sound form the TV to play through the speakers in the trailer? The stereo has an A, B, C switch but none of them seem to allow the TV sound. I've looked in all the manuals and found nothing referring to this. The TV volume seem very low even when turned all the way up. Thank you for any advise.
2013 Rockwood Roo 23SS
2007 Toyota Sequoia
tduff is offline   Reply With Quote
Old 05-30-2016, 03:04 PM   #2
Have you looked into changing the source on the stereo?
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 05-30-2016, 08:40 PM   #3
Make sure your audio wires are connected to the tv and to the stereo
VetteJohn is offline   Reply With Quote
Old 05-30-2016, 08:51 PM   #4
raspivey's Avatar
I'm assuming it's a Genesis unit. Stereo needs to be on AV1 (not AU1...) using the Mode button. You should have some RCA cables on the output side of the TV going into the input of the stereo. Check that if the mode doesn't work. You A B C buttons turn sets of speakers on/off. My C channel is for the outside.
Old 05-31-2016, 12:24 PM   #5
I have a Roo 183 with an iRV unit. There is a "TV" input on the radio. Just hit the "Mode" button until it says TV in the display. TV audio should come through your Trailer speakers. This assumes all of your wiring is correct. There seems to be a lot of issues with that from the factory.
Mine is a 2016, not sure if it's the same with your 2013...
ebcobra93 is offline   Reply With Quote
Old 05-31-2016, 01:50 PM   #6
NMWildcat's Avatar
Agreed. If it's not the settings then check your wiring. I finally got tired of ours not working as advertised and pulled the stereo and found the TV audio wasn't hooked up and the surround sound speakers were all wired together giving us mono. Plugged all the wires into the correct connections and now it sounds GREAT!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 05-31-2016, 02:28 PM   #7
There should be a red/yellow pair of RCA cables running from the TV audio out to the back of the iRV unit. When I purchased my trailer, the cables were on the wrong TV ports.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
Old 05-31-2016, 02:31 PM   #8
jeff64's Avatar
Yes, and the SRC button should be set to TV AUDIO if the unit is the iRV66
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 05-31-2016, 09:46 PM   #9
Mine does the same thing. It's a genesis.
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 06-25-2016, 09:54 PM   #10
Does anyone have issues with the volume control on the exterior speakers?
2017 Roo 183
gderose is offline   Reply With Quote
Old 06-29-2016, 07:17 AM   #11
karrun's Avatar
2017 Roo 183
See this thread
http://www.forestriverforums.com/for...on-107688.html
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 06-29-2016, 07:32 AM   #12
Stereo speakers
How about this one?
The surround sound sounds great, except. The TV speakers don't work.
I have gone into the menu and set them for tv only, but nothing works.
The only thing that works IS the surround sound. ideas.?
PLUS,,does anybody know where the inverter is actually located on the 37FliK?
thks
roodman is offline   Reply With Quote
Old 07-11-2016, 06:55 PM   #13
Ben M's Avatar
I ran a double male jack from the headphone jack on the tv to the input ( I believe it is aux1) on the stereo. It works great.
Ben M is offline   Reply With Quote
Old 07-12-2016, 04:31 PM   #14
'thanks...I will give that a try...
Old 07-12-2016, 07:08 PM   #15
I have a 2015 passport grand touring and can't get the tv sound to play thorough the speakers on the trailer. I switched through the mode button and did not option for tv
Cjames is offline   Reply With Quote
