Old 10-18-2017, 09:27 PM   #1
urocav2001's Avatar
Winterization
Does anyone know what the PSI is to blow the lines out to winterize? It’s a 2016 233s. Thanks in advance
urocav2001 is offline   Reply With Quote
Old 10-18-2017, 09:34 PM   #2
cheeseheadjim's Avatar
30 psi max
2018 Flagstaff 25FKS
2015 Ram 1500
cheeseheadjim is offline   Reply With Quote
Old 10-18-2017, 09:46 PM   #3
If your water pressure regulator is set to 45 psi, than I'd say using 45 psi is fine.
That's what I do.
2011 Traverse LT, 3.6L, FWD
Old 10-19-2017, 07:21 AM   #4
WFD
I set my compressor to 40psi.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-19-2017, 04:45 PM   #5
urocav2001's Avatar
Ok thanks !
Old 10-22-2017, 02:45 PM   #6
Add the anti-freeze. I made the mistake thinking blowing out the lines would do it on our last camper just like it does on a sprinkler system. They sell so many of those toilet valves every spring because of the blow out doesn't get all of the water and all it take is less than a thimble full that will run back down the inside of the rim where the water comes out back onto the valve and freeze and crack it. Then the valve is overpriced and on my camper required removing the whole toilet to get to it, that's a crappy job in itself.
The rv antifreeze is so cheap, why add the step blowing out the lines first? the antifreeze will push out the water. Just make sure to bypass the hot water heater.
PS you won't know it is split until you go fill the system up in the spring, and pressurize it with the pump or the outside hose. Then it starts flooding the bathroom with no isolation possible meaning the whole system is down until fixed. Hopefully this isn't as you planned on leaving for vacation!
Hersbird is offline   Reply With Quote
Old 10-22-2017, 02:54 PM   #7
urocav2001's Avatar
I’ve always blown out the lines before, this also removes the water in the city water line hookup, then I also add antifreeze, never had a problem in any of my campers I’ve owned and used this process, I know it’s probably overkill or an extra step but I know it’s straight antifreeze all the way thru the unit... I also spray out the tank flush fitting with minimal air to be sure that’s cleared out as well..
Old 10-30-2017, 07:18 AM   #8
Send a message via AIM to eprovenzano Send a message via MSN to eprovenzano
I live near Pittsburgh PA... in the early fall I'll use the pressure method to blow out the lines, but prior to putting her away for the winter, I'll pump antifreeze into all the water lines. Better safe then sorry
2013 Palomino Stampede 23S HTT
2015 Dodge Ram 1500 6" lift rolling on 35's
eprovenzano is offline   Reply With Quote
Old 10-30-2017, 07:19 AM   #9
urocav2001's Avatar
Same process here in Syracuse NY
Old 10-30-2017, 05:40 PM   #10
I blow the lines at 40 PSI. It's easy, quick and can save a lot of heartache. Antifreeze is cheap, about $2.50 a gallon and I generously push it through the lines, drains and tanks.
2 in a Roo is offline   Reply With Quote
Old 10-30-2017, 06:01 PM   #11
The_Rhino's Avatar
I do the same, set the dial to 40 psi & blow-out all lines. Then generously use RV antifreeze until it runs through every line. The gray & black tanks are empty so I let the antifreeze build-up around the waste valves & low point drains so the seals do not freeze/crack.
Make sure you drain your HW tank & bypass it when adding antifreeze.
2011 RAM 2500 ST Crew Cab 5.7 Hemi
2011 Primetime 3150BHD Touring Edition
Days camped in 2018-25
2017-31; 2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
winter
