Old 11-07-2015, 02:28 PM   #11
Summer2Go
Summer2Go's Avatar
The low point drains in a Roo183 are where? I see a sticker where my fresh water tank is labeled fresh water drain. Would like to try my 1st winterization, but I can't find these drains.
Summer2Go is offline   Reply With Quote
Old 11-07-2015, 02:30 PM   #12
Engineer of Crazy Train
ChooChooMan74's Avatar
There are 2 sets on mine. First set, left side, just in front of the wheel. 2nd set, back right corner.
Sent from my Samsung Note 4 using Tapatalk.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 11-07-2015, 04:22 PM   #13
Summer2Go
Summer2Go's Avatar
Wow! Thanks ChooChoo! I finally found the set in the back corner under the bathroom. Can't find the other one though. My freshwater tank maybe the reason though, it has a little plastic knob to completely empty the fresh water tank, on the bottom of the tank. Maybe that is a 2016 thing? I want to see if I can blow out the lines and use minimal antifreeze, I have to get the toilet fixed, it doesn't hold water.
Old 11-07-2015, 04:55 PM   #14
I have a 2015 183.
Locomotive Engineer
Old 11-08-2015, 11:58 AM   #15
Summer2Go
Summer2Go's Avatar
Do you have a white plastic drain on the bottom of your fresh water tank? I'm thinking that is why I don't have the extra drain in front of the wheel. I have a sticker on the outside of the trailer labeling the fresh water drain.Click image for larger version
Name:	ImageUploadedByForest River Forums1447005283.356194.jpg
ID:	93891Click image for larger version
Name:	ImageUploadedByForest River Forums1447005353.974032.jpg
Old 11-08-2015, 12:01 PM   #16
Summer2Go
Summer2Go's Avatar
Sorry it wouldn't post.
Old 11-08-2015, 05:28 PM   #17
Yes, I have a fresh water drain. Maybe my 2 low point drains are a goof up?
Locomotive Engineer
Old 11-08-2015, 07:54 PM   #18
Originally Posted by ChooChooMan74 View Post
We did our final campout this weekend at Normandy Farms. I have my final week of vacation, so perfect time to winterize Bertha. I am a belt and suspenders man, so blow and pink stuff for me. I already had a home made blow out adapter, so I just got some tubing and a barbed nipple to make a antifreeze suck tube. Also made a water filter bypass. Well winterizing this thing is a piece of cake with the factory setup.
My AF suck tube
Attachment 93592
My water filter bypass.
Attachment 93593
I used up 2 gallons, including pouring a bunch down each P trap. I had bought 3 when we had a 20 degree night a few weeks back, where I blew out the lines and added some to the P traps. So, I got 2/3 of a gallon left.
ChooChoo. What size of plastic tubing did you use 1/2"? What type of fittings did you use to connect to the A/F line? It looks like a garden hose fitting. Is the barbed nipple the piece that connects to the female garden hose fitting? Is the pump strong enough to suck the A/F through the plastic tubing. Sorry for so many questions. Just want to do it right.
JWHybrid2B is offline   Reply With Quote
Old 11-08-2015, 08:13 PM   #19
I believe I used 1/4 ID, but don't quote me. I built this contraption at HD. I got the 3/4 Male Garden Hose and I believe the female is 1/2 NPT. My nipple for my air compressor is 3/8 NPT, so I had to step it down with a 1/2 to 3/8 adapter. I then got the 3/8 NPT to 1/4 Barb with tubing. I thought it would suck slow, but it did quite well.
Mod Idea. If you have an AF inlet, I was thinking of modding a valve from the pump outlet to the tank. Then, you can pump water into your tank when boondocking.
Locomotive Engineer
Old 11-14-2015, 08:09 AM   #20
yetavon's Avatar
Originally Posted by jizmo3 View Post
got a 16 shamrock 233s, was wondering what to do so i didnt have to use anti freeze to fill the water filter housing.
is there a bypass on there factory installed or was that added after?
I removed the filter element and used a 20 once tea bottle to take up the space.....
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
roo, winter, winterize
