Old 11-02-2015, 09:38 PM   #1
Engineer of Crazy Train
ChooChooMan74's Avatar
Winterizing the New Roo (Oh My So Easy)
We did our final campout this weekend at Normandy Farms. I have my final week of vacation, so perfect time to winterize Bertha. I am a belt and suspenders man, so blow and pink stuff for me. I already had a home made blow out adapter, so I just got some tubing and a barbed nipple to make a antifreeze suck tube. Also made a water filter bypass. Well winterizing this thing is a piece of cake with the factory setup.
My AF suck tube
My water filter bypass.
I used up 2 gallons, including pouring a bunch down each P trap. I had bought 3 when we had a 20 degree night a few weeks back, where I blew out the lines and added some to the P traps. So, I got 2/3 of a gallon left.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 11-03-2015, 07:05 PM   #2
Thunderbolt75's Avatar
Looks great!
We're off on a four day weekend later this week but that exercise isn't far away for us either.
Be safe, but if you cannot, be violent.
Choose to be a winner, not a victim.
Thunderbolt75 is offline   Reply With Quote
Old 11-04-2015, 01:47 PM   #3
Bobaloo's Avatar
I did mine last week, felt good and bad at the same time. It's gonna be a long winter.
Bob
2013 Rockwood 2504
2015 Silverado 1500 4x4 Z71 Double Cab
Diablo and Lew Custom tuned
Tony & Catnis, campin' kitties
Bobaloo is offline   Reply With Quote
Old 11-04-2015, 05:50 PM   #4
I was winterizing my Roo today. Removed filter. Emptied hot water tank. Switched bypass valves. Switched pump input to anti-freeze line. I also emptied all 3 tanks and the low point drains and blew everything out. I closed the three drains.
When I pumped in the anti-freeze I got nothing coming out the hot water side of any faucet. Is that normal? The plug is out of the hot water tank so I know it is not going there? Does using the bypass valves effectively switch the system to all cold?
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
Kanga99 is offline   Reply With Quote
Old 11-04-2015, 07:59 PM   #5
Doublecheck the 3 bypass valves on the hot water side. You should get AF on both sides.
Locomotive Engineer
Old 11-05-2015, 02:51 PM   #6
X2
2015 Shamrock 231KSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017, 37 in 2018
CNYCamper is offline   Reply With Quote
Old 11-05-2015, 06:33 PM   #7
Canadian Member
The valves should look something like this. Closed position is when the handle is perpendicular to the water line. Open position is when the handle is parallel to the water line.
In this picture the valves on the cold and hot lines are closed and the valve on the bypass line between them is open.
2019 Rockwood Signature 8290BS
Old 11-05-2015, 06:36 PM   #8
It is possible that you have all 3 valves closed at the HW bypass. If you have a 3-valve bypass system, the cold-in should be in the off position, the center valve open, and the hot-out closed. This will allow antifreeze to bypass the heater.
PenJoe is offline   Reply With Quote
Old 11-06-2015, 11:37 AM   #9
water filter bypass
got a 16 shamrock 233s, was wondering what to do so i didnt have to use anti freeze to fill the water filter housing.
is there a bypass on there factory installed or was that added after?
jizmo3 is offline   Reply With Quote
Old 11-06-2015, 12:16 PM   #10
There is no factory water filter bypass. I use the Camco 12" water heater bypass. It also gives you the option to bypass the filter if it clogs up. But, if your water source is clogging your filter, you may not want to bypass it.
Sent from my Samsung Note 4 using Tapatalk.
Locomotive Engineer
roo, winter, winterize
