Old 07-16-2015, 12:58 AM   #51
dado39's Avatar
Just had water filter come off on me today well camping on our 6th day out of 9 on my 2014 roo 233s just got back to the camper and It let go found the filter and bowl in the bottom of cabinet. Cleaned up put it back on wacth it start to unscrew itself when water came back on re tightened held for 5 min and did it again ! Removed filter and used a spare shower hose to patch it till home depot opens to get 1/2 coupling. Now another thing for the dealer to fix !!!!
2014 roo 233S. 2008 saab 97x
dado39 is offline   Reply With Quote
Old 07-16-2015, 01:01 AM   #52
dannyabear's Avatar
No need for dealer; just get a threaded coupling and remove the filter housing.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 07-16-2015, 01:05 AM   #53
dado39's Avatar
Going to do that but I paid extra for the whole house filter so dealer will have to fix it with a new one !
Old 07-16-2015, 01:33 AM   #54
SYE
SYE's Avatar
If it is a FR1 Canister that takes the KW1 filter, someone probably over tightened it 1 time, or tightened it without a filter in it and broke the locking tabs off of the canister. After this the canister will unscrew itself.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 07-16-2015, 05:43 PM   #55
deartruc's Avatar
X2 on the coupler. Yup, paid $70 for the filter that now sits on my garage floor. I also think it was factory over tightened. Was a bear to unscrew but now it does it on its own.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 07-16-2015, 06:30 PM   #56
Canadian Member
itat's Avatar
I want to either relocate mine or remove it and use it outside. The factory installed it in a very awkward place to access. I want to drain the water from the filter housing between trips so the water doesn’t go stale and it's a PIA to work with where it is now. Mounting it outside would avoid spilling water all over the floor when removing the canister to empty it.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 07-16-2015, 06:42 PM   #57
Red Wolf's Avatar
At least you guys can reach your filter. I have to access mine from the left front hatch, remove the basement wall panel, and looking back in there, can see it past the furnace, past the outside water connections, past the exterior shower assembly...
If I stick my arm in there to the shoulder, I can *just* touch the darn thing. Who thought this was a good design?
It's on my list of things to do this month to remove the exterior shower assembly, reach in there and remove that silly filter system. (There's no filter in it, it's just a bowl of water)
-Red
Big Bad Wolf - '15 Dodge Ram 2500HD 6.7 CTD / Reese 15k Pro
Wolf Den 3 - '14 Rockwood Signature Ultra Light 8280WS
Nights camped 2017: 12
Red Wolf is offline   Reply With Quote
Old 07-16-2015, 06:50 PM   #58
A coupling will require turning one of the Pex fittings which is not good. He needs a Union.
Homewerks Worldwide 1/2 in. Sch. 40 PVC FPT x FPT Union-511-44-12-12B - The Home Depot
Old 07-16-2015, 07:00 PM   #59
I didn't have to turn a pex fitting when I installed my coupler.
jdubs is offline   Reply With Quote
Old 07-16-2015, 07:06 PM   #60
DaveSchwartz's Avatar
I would have had to turn one of the fittings to remove it anyway. One side was PEX and the other side was a reinforced vinyl stub. I chose to cut the crimp ring on the vinyl stub with a side cutter and use a ring clamp when reinserting it after the coupling was installed.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
water, water filter
