Old 07-17-2015, 09:42 AM   #71
dado39's Avatar
The brass barb will turn inside the pex tubing I just held the tubing with my hand . no problems or leaks after.
2014 roo 233S. 2008 saab 97x
dado39 is offline   Reply With Quote
Old 07-17-2015, 09:45 AM   #72
You were lucky.
Old 07-17-2015, 03:05 PM   #73
Originally Posted by howie70 View Post
I understand you unhooked the one hose from the pump, but how did you get the other hose unscrewed from the filter without turning the pex fittings?
Unhook hose from pump, hold wrench on inlet side of filter housing, turn filter housing till it comes loose from inlet hose, remove pump side hose from filter housing. Install threaded coupling on inlet hose, install pump hose onto threaded coupling, attach hose back on pump.
jdubs is offline   Reply With Quote
Old 07-17-2015, 04:23 PM   #74
Canadian Member
itat's Avatar
I have a Water Pur CCI-10-CLW filter housing. The pipe from my pump to the filter housing is 1/2" pex with at least 3 - 90 deg. horizontal and vertical bends in between. I think the filter housing is connected to the pex on either side using threaded white plastic connectors clamped to pex pipe.
The way that mine is plumbed, unless those white plastic threaded connectors rotate, I think I'm going to have buy a pex pipe cutter, some new pex pipe and sharkbite fittings in order to remove the filter housing and fill in the gap.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 07-17-2015, 04:28 PM   #75
If you're going to scrap the filter, just remove the canister and cut the base in two with a hacksaw/cutoff wheel and unscrew the fittings and get a 1/2" UNION and connect them back together. You might need a short nipple if the pipes are too far apart and can't be moved.
Old 07-17-2015, 08:39 PM   #76
Canadian Member
itat's Avatar
I don't want to get rid of the filter housing. It's just in a very awkward place to try to unscrew the canister. I want to either relocate it to a place that's easier to get at, or make a portable mount for it outside.
Old 09-29-2015, 12:29 PM   #77
Water filter cartridge for 2015 mini-lite 2109s
I bought this unit barely used and there is no cartridge in the filter housing.
Surprise dealer no help. I need the filter make & model# and the cartridge# and where to purchase info.
Thanks in advance
dlcrane is offline   Reply With Quote
Old 09-29-2015, 12:37 PM   #78
rsdata's Avatar
any stock water cartridge filter available at box stores or local hardware store should work... they are pretty standard size, only different filtering specs as the prices goes up...
take the empty holder with you to confirm this when you go to purcahse
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 09-29-2015, 01:49 PM   #79
bikendan's Avatar
my 2007 Roo has a stock filter but i thought the newer ones don't have a stock cartridge anymore.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-29-2015, 02:54 PM   #80
rsdata's Avatar
My 2014 Shamrock 183 was a stock size... I just took it out and went to an external filter from Walmart... much easier to maintain and no possible hidden water damage from a faulty filter install
2014 Shamrock 183
water, water filter
