Old 09-29-2015, 08:43 PM   #81
Canadian Member
itat's Avatar
Originally Posted by dlcrane View Post
I bought this unit barely used and there is no cartridge in the filter housing.
Surprise dealer no help. I need the filter make & model# and the cartridge# and where to purchase info.
Thanks in advance
Do you know what the canister model is? If not, just post a picture and someone will will be able to help.
It may or may not take a "stock" size filter but you'll have to decide if you want the filter to capture just sediment or if you want a finer filter to capture smaller particles. Look for the filter opening size in microns and the flow rate.
Here's a few links:
OEM Filters
WaterPur Filters
You likely have either the KW1 filter or the CCI-10-Ca filter.
The RV Water Filter Store - lots of good info here
https://www.rvwaterfilterstore.com/
https://www.rvwaterfilterstore.com/ABFiltration.htm
https://www.rvwaterfilterstore.com/A...ACartridge.htm
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 10-20-2015, 10:46 PM   #82
Well after a month of sitting in the driveway. The threat of a freeze sent me out to make sure that I drains as much water out that I could. I took the the cabinet blank off to show the pump and the filter was naturally full of water and also algae. CRAP! Forgot to drain that! Well next thing I knew the filter is removed cut out and pex fittings complete the connections. Done! I figure I use a filter inline on the hose s why would I keep it. Fyi the supply side was of thw filter was 1/2 hose and the filtered side of the filter was 1/2 pex. Which means that one side of my pex 90 has a hose clamp. Not my fave rate but camping this weekend let ya know if any issues arise.
CAMP ON!
1st timer is offline   Reply With Quote
water, water filter
