Old 06-26-2011, 09:31 AM   #1
myfirstroo21ss's Avatar
Zx75 dvd/radio
Any idea how to hook the DVD player to the tv? There is one aux input on the left but is this a special cord?
myfirstroo21ss is offline   Reply With Quote
Old 06-26-2011, 07:10 PM   #2
Never mind just figured it out! I was thinking I needed audio and video when all I needed was video!
Old 10-29-2012, 03:55 PM   #3
Hi
I know this is an old post but we cannot figure how to get the DVD to play picture on TV... we get the DVD playing because we hear it thru the speakers but no picture on TV. We have no issues with watching TV with the Antenna but not sure what cable we need and were is the connection on the ZX75? What cable did you use from the ZX75 to TV and where did you connect the cable? Thanks Ron and Wyndi
RonandWyndi is offline   Reply With Quote
Old 10-29-2012, 07:19 PM   #4
miatared's Avatar
Typically you will have a single Yellow (Video input) jack at the back of your TV (along with a Red and a White one, this is for audio only, LH and RH channels, not used by the ZX75). It is the lowest quality connection method by today's standard, HDMI is the way to go now, but the ZX75 does not support that method.
Simply connect that single jack to your wall plate, it has the same connector. You only need 1 cable.
When you insert a DVD, the audio tracks will play on the trailer speakers, the video will play on the television, provided you have changed the Input or Source on your television, look at your remote for the TV, you should see an Input or Source button, by pressing it it will rotate between options, like Antenna/Air, PC, Input 1, HDMI and so on.
Good luck.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 10-30-2012, 03:44 PM   #5
Thank you.. we are going to go get the cable today. Will let you know and so thankful for this forum..we already solved a slide out issue with reading blogs. Ron and Wyndi
