06-28-2017, 02:00 AM
motorcycle chocks
I bought a work and play 19ft, no carpet, but I am wanting to put some motorcycle chokes in it but I don't know what kind of hardware for these floors? and if they make wheel chocks that don't have to be bolted down? any help would be great....it has that hard floor kinda like a spray in bed liner....thanks Murh68
06-28-2017, 07:26 PM
thanks for feedback I will look into this bar system... thanks
06-28-2017, 07:29 PM
The BOLT IT ON SYSTEM doesn't require any cutting.
06-28-2017, 07:51 PM
Scroll down to the Cherokee forums and look for 'Pimp my 26RR'. Check out how rmac has set his front wheel chock which he can remove and get out of the way. You might be surprised. The wheel chock is always back in the same place each time it's re-installed.
Good luck with what system you choose.
edit to add ~ the Cherokee forum is listed under Toy Haulers
06-28-2017, 10:17 PM
flooring
does anyone know on these work and plays what kind of installation will work ...like bolting down or self tapping..my floor is not carpet but rather looks like a spray in bed liner?
06-29-2017, 03:01 AM
motorcycle chokes
I have a work and play..I don't really know what type of application to either self tapping bolts or what? the floor is not carpet ..it has that spray in bedliner texture.....any suggetions would be great...
06-29-2017, 05:23 AM
I went with the "lock n load" system in the trailer I carry my motorcycles in. The reason being that you mount an attachment plate to the floor which allows the chocks to be removed when not using them.
In my case, I was able to access the underside of the flooring so I went with bolts, washers, locknuts, and nuts to mount the plates. I suppose if I couldn't access the underside to install nuts and had to use self tapping bolts, I would make sure that at least some of the bolts went into the metal floor framing.
Hope this is of some help.
06-29-2017, 08:10 AM
I believe this thread refers to motorcycle chocks... The OP has started a new thread ( http://www.forestriverforums.com/for...ks-137817.html) and there are more responses there.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
06-29-2017, 11:58 PM
Constantly Confused
This is my KLR 650 in my 22RR with the boltiton system.
07-01-2017, 10:56 AM
I bought mine this way. 4 bolts hold the chock in. I have a battery impact with a Socket for the chock and another socket for jacks. In and out in 2 min. When it's out, just the right amount of room for an 8' Boat.
09-06-2017, 09:39 AM
I don't have a toy hauler but do have a cargo trailer which I wanted to transport two (2) bikes. I had some 1/2" plywood lying around so I cut two (2) pieces which were long enough for both of the bike tires to fit onto and a little extra for the wheel chock. I bought the wheel chocks from Northern Tool and they are very much like the one in the video minus the straps. When I load the bikes the rear tire gets onto the board, holding the board down, just as the front tire gets onto the wheel chock then the front tire locks in. I can position the board anywhere in the trailer and use this system. After securing the front wheel into the wheel chock I use four (4) straps per bike to secure them to hold-downs mounted flush with the floor, yes I did have to alter the flooring a bit for these but they are flush and not in the middle. This has worked on numerous trips with one or two (2) bikes. I also use this trailer for other reasons so I didn't want anything sticking up permanently in the middle area of the trailer.
09-12-2017, 06:48 PM
I mounted a BikerBar to the floor of the W&P. Couple bolts in the floor and done. No straps needed.
Ride Safe, Wave, I'll Wave Back.
Retired Paramedic, Emergency Dept. Director.
2014 Work and Play 38RLS, Black, no decals.
2012 Ram 3500, diesel, 4X4, dually, black, de-badged.
1994 Harley Heritage Softail, black.
2014 Honda Pioneer, not available in black.
11-13-2017, 10:48 PM
When I bought my 26RR I thought I would have no problem loading my Harley Ultra limited and Street Bob together. I put my ultra in first and had no problem. I used a Harbor Freight chock, not attached, and four tie downs. I put a no slip tool box liner under chock to protect floor and help keep chock from moving. When we put Street Bob in it was obvious the chock would not be able to go on front wheel. So we loaded bike in first and then put the chock in the back and put rear tire in the chock. Used the four tie downs and got both bikes in with no problem. Tight fit up front but plenty of room in the back. Ha ppy how it turned out.
12-18-2017, 11:36 AM
Here is what i built to haul my 2004 Yamaha Vstrom 1000. I wanted something that i could easily take out, but still held the bike stable.
There are cut outs in the plywood that the flip up hold downs fit into. I use 4 ratchet straps, and put a piece of 2X4 between the fork stabilizer and triple clamps. This way it doesn’t compress the forks all the way down. When i get to the campsite, it takes a few minutes to unload the bike and set this under the camper. Cost was a few hours of labor, as i had material already sitting around.
12-27-2017, 08:21 AM
Good to see someone else hauling 2 bikes. We're new to RV'ing got a nice 22rr to haul our 750 Shadow Phantoms. We ordered the chocks for the front wheels and I am going to spend this winter figuring out the best placement for them. My idea is to install some flush mount bolt plates so the chocks can be removed and the holes for the bolts covered with some push in trim fasteners. Playing with the idea of custom building/ remodeling the cabinet so that we can get the Polaris 400 in there. But that's another cat to skin.
01-07-2018, 07:39 PM
Jerry & Carol
Mason, il
2014 Grey Wolf Toy Hauler 25RR
Pulled with our Chevy Suburban.
