Old 03-24-2018, 09:51 AM   #1
Motorcycle hauler
tom848 is offline   Reply With Quote
Old 03-26-2018, 07:43 AM   #2
SeaDog's Avatar
Looks like a nice setup plan on the bike getting plenty of dirt on it while traveling.
Retired Navy
2016 Flagstaff 26 FKWS
Old 12-26-2018, 08:03 PM   #3
I added a bottom pan and have cover over the bike. The bike stayed pretty clean.
Old 01-15-2019, 02:33 PM   #4
2thdr's Avatar
Don't know how much moto trailering experience you have, but I never transport a heavy bike using the passenger footpeg hangers as tie down points. I like to get a soft-tie wrapped around a frame member if at all possible. Then up front I use soft-ties around the fork tubes on the upper triple clamp. Much less likely to have bad things happen...
Your Versahaul is sweet!
2019 FR Cherokee Wolf Pack 24pack14+
2019 Ford F250SD 4 x 4, 6.2L
2015 DL1000A ADV
2017 DR-Z400 SM
2thdr is offline   Reply With Quote
Old 01-16-2019, 08:40 AM   #5
My family and I have trailered pretty much everything, Gold Wings, minibikes, sport bikes, dual sports, cruisers and motocrossers and have never had an issue using passenger peg mounts as tie down points, provided you do it correctly.
Every motorcycle should be tied down by the front straps as your MAIN support and rear should only be stabilizers. If you do it right, you can have one of the front straps come completely loose and the bike will still be stable and stay put. In 40 years of trailering stuff I’ve NEVER had one tip over in transit, though I’ve had a strap loosen and a had a wheel chock dislodge a time or two.
Passenger pegs are designed to hold up a persons full weight, so I think you’ll have a soft tie failure before a foot peg mount failure.
Current:
2019 Rockwood Roo 24ws
2016 Chevy Silverado Z71 4x4 DC
Past:
2001 Starcraft Spaceliner PU
1987 Starcraft Nova PU
Miweber929 is offline   Reply With Quote
Old 01-16-2019, 08:53 AM   #6
I manufactured my own. The front and rear have independent soft handlebar & chassis straps with tied downs to chassis.
Question - Do you use a cover when moving on the Interstate Highways? Max speed?
Name:	Rack Back Side View-01.jpg
ID:	194710   Click image for larger version
Name:	Rack Back View.jpg
270S is offline   Reply With Quote
Old 01-16-2019, 11:54 AM   #7
similar set up on my fifth wheel, but with the moto jack rack. now I'm dreaming up a new mounting system using the moto jack footpeg tie down with a rail like these. Pics when its done. I wouldn't do it until I had a rearview camera though. Not being able to see it was not an option for me. I haul a 450 dual sport, just under 300#.
nayther is offline   Reply With Quote
Old 01-16-2019, 01:12 PM   #8
2thdr's Avatar
Exactly why I put the qualifier at the beginning of my post... it's hard to argue with success over time. I have seen passenger footpeg hangers on other folks' bikes fail...maybe they had them strapped down so tightly the suspension was bottomed out. I don't think my soft ties are any more likely to fail than any of yours or my cam lock or ratchet tie downs that use the same webbing. I, like you, have had a wheel chock break loose before when I was transporting three bikes cross country in a moving van.
2015 DL1000A ADV
2017 DR-Z400 SM
Old 01-16-2019, 03:17 PM   #9
Only a Harley rider worries about those things
Delnari is offline   Reply With Quote
Old 01-17-2019, 05:03 PM   #10
2thdr I have been hauling motorcycles for over 40 years.
I have made a change to the hauler to hold the front axle. Similar to the Pit Bull.
The canyon dancer hold down works well. I haul my race bike in the trailer with a front wheel motorcycle chock and the canyon dancer thousands of miles with no problems
Old 01-20-2019, 05:01 PM   #11
Webefine's Avatar
ID:	195018Click image for larger version
I haul my V Strom on the back of my DX3. I added 2 more receivers on the outside legs of the hitch, then I slip in two pieces of 2” tube steel. This takes all of the wobble out of the rack.
Webefine is offline   Reply With Quote
motorcycle
