Originally Posted by mharold101
I was just informed by a motorcycle carrier mfg. that "no" motorcycle carriers are designed for use with RVs because of the longer distance from rear axle to carrier. Is this true? Is there no safe way to carry a 300 lb bike on the hitch?
I call BS on that statement. Yes there is some weight transfer if you hang it off the back, more on rear axle, less on front. What size/weight bike are you hauling? I haul a 250# dual sport on the back of my trailer via a frame mounted receiver. I've seen a TON of bikes like mine on the back of RV's. A close friend hauls his DS on the back of his older class C, works great. It does add to the rear overhang so you have to be careful in driveways.
