Old 07-08-2016, 08:16 PM   #11
scootingranny's Avatar
We have them all over the 5er. The ones that came loose were because we didn't clean the area with rubbing alcohol first or didn't let them "cure" for awhile. Do both of those things and they will serve you well. Haven't had any issues with it doing any type of damage to the wallpaper.
2015 Coachmen Chaparral 360 IBL
2014 Ram 3500 Turbo Diesel 6.7 4wd Crew Cab Dually
scootingranny is offline   Reply With Quote
Old 07-08-2016, 09:12 PM   #12
WFD
So far sounds like a fairly mixed reaction, perhaps has to do with how well the wallpaper was applied in the first place or perhaps humidity and the like.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-09-2016, 06:03 AM   #13
Wolverine 1945's Avatar
The vinyl covering on a RV wall should never come loose ???
Unless the Chinese are not using enough glue ???
The contact paper on the sides of the cabinets is a different story !!!
Our Menards has a very large display of Command products !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-09-2016, 04:50 PM   #14
Friends of ours put command hooks OUTSIDE the trailer on their Eagle (I realize there isn't wallpaper there). They use them to hang clocks, thermometers, decorations, etc. and have done so for several years. Command hooks seem to last pretty well during Chicago weather. Of course they remove everything hanging on them before they travel.
rogerkathy is offline   Reply With Quote
