Old 02-23-2018, 02:09 PM   #1
KsKev's Avatar
4 power stab jacks
hi everyone.....
I have a Flagstaff 26RLWS and have 4 POWER STABILIZER JACKS !
Getting ready to take it out for the 1st time....notice one switch for the front stabilizers and one switch for the back. and when pressing lets say front switch they both come down together!
SO, if your on unlevel ground and use leveling blocks to level the TT, and I deploy the POWER STABILIZER JACKS and they come down together (front ones) and what happens if one stabilizer touches the ground lets say 3 or 4 inches before the other one does.... does it stop till the other side makes contact with the ground?
I know these are not for "LEVELING" the TT so what happens?
Don't want to twist the frame or anything on the TT from not doing it right!
Thanks and interested before heading out!!!!
KsKev
KsKev is offline   Reply With Quote
Old 02-23-2018, 02:13 PM   #2
Mr. Dan's Avatar
Run a set of stabilizers down half way and stop. Push down on the foot on one side. Does the other foot go UP? Mine does. Mine will equalize. I could put a 4" block under one side and nothing on the other (I don't) and they will equalize if your stabilizers are like mine.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 02-23-2018, 03:39 PM   #3
raspivey's Avatar
If one side makes contact, the carriage will shift to the other side until there's pressure on both sides. My last trailer had those (the new one has individual on each corner...I found those more stable for some reason) and, after awhile, one side would run down slightly faster than the other. Never had a problem with them.
Old 02-23-2018, 03:41 PM   #4
Weekend Warrior
KyleStout's Avatar
They will auto-equalize...
Frankly though, they suck.. invest in a few jack-stands, they offer much more stability. IMHO
KyleStout is offline   Reply With Quote
Old 02-23-2018, 03:49 PM   #5
Just A Member
EDABEUT's Avatar
Short answer - Yes they will equal out. When I first got my TT with them on there I had to have the DW run them up and down so I could figure out how they work. Play around with them and get comfortable. I actually often run mine down until the motor kicks out. If they are Lippert stabilizers they will only take so much pressure and then stop.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 02-24-2018, 05:05 PM   #6
bedubya's Avatar
I was doing that, too, and did not have a problem. Then I read the manual (what a concept!) It says only run 1-2 seconds after they both hit bottom.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
Days Camped: 2017-39, 2018-58, 2019-64
bedubya is offline   Reply With Quote
Old 02-24-2018, 05:28 PM   #7
Most Definitely if you run to long you will bend or break them. Mine has some sort of sensor that will shut them off if you run them to far (resets on its own and they then work again a few minutes later)
Kimber45 is offline   Reply With Quote
Old 02-25-2018, 12:57 AM   #8
That’s one of the reasons. Didn’t want electric stab jacks. They don’t work as well and why would I put 4 expensive motors in the lelements if they don’t work well.
quicky06 is offline   Reply With Quote
Old 02-25-2018, 06:53 AM   #9
NH Maple Maker
russhd1997's Avatar
My TT has Lippert electric stabilizers and I didn't know that they would equalize. I was putting blocks under the leg that doesn't touch the ground first. I will be trying out that feature when I get my TT out in the spring.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is offline   Reply With Quote
Old 02-25-2018, 07:17 AM   #10
Locky's Avatar
Do you guys find that these jacks are not as sturdy as the old crank down scissor jacks?
Locky is offline   Reply With Quote
Old 02-25-2018, 07:25 AM   #11
Depends "What Type/Style" crank down scissor jacks ,but in Most cases the "Old Style" are More Stable! Youroo!!
Old 02-25-2018, 07:51 AM   #12
Handyman
Electric jacks might not be quite as stable as the old style, but they are a whole lot easier for an old man to set up. I love mine.
2016 Salem Cruise Lite 253RLXL
2013 F-150 XLT 5.0 Crew Cab
2009 F-150 King Ranch 5.4 Crew Cab
tfmdgm is offline   Reply With Quote
Old 02-25-2018, 08:03 AM   #13
The legs are fairly easy to reinforce with some 2-1/2" x 1/8" sq. tubing split lengthwise and welded to the underside of the legs.
Name:	Stab Leg reinforcments ready to trim.JPG
ID:	163337   Click image for larger version
Name:	Modified Jacks extended.JPG
Old 02-25-2018, 08:46 AM   #14
KsKev's Avatar
Thanks everyone for the responses, now I don't know if they are a good deal or not from the opinions here! BUT there on the unit and will try them out and hope for the best!
IF they are not to my liking, guess I'll replace them with the manuals ones..... will see!
Again, thanks all!
KsKev
Old 02-25-2018, 08:56 AM   #15
bedubya's Avatar
I love 'em too. Mine can be controlled with a remote or the switches on the side.
Old 02-26-2018, 11:29 AM   #16
MartiB's Avatar
I love my stabilizer jacks. I haven't really noticed any difference from my old Dutchmen with the jack stands. Sure is a lot easier for me to set up.
Marti
2015 Salem CruiseLite 241QBXL
2016 Nights Camped: 30
2015 Nights Camped: 17
MartiB is offline   Reply With Quote
Old 03-18-2018, 09:23 PM   #17
Thatís a big ďAMENĒ
PharrOut is offline   Reply With Quote
Old 03-18-2018, 09:45 PM   #18
frostriver's Avatar
Had scissor jacks on our old pop-up and on the hybrid. Opted for the power stab jacks on the 832BHIKWS but also put 4 JT strong arms on the back, where the bunk is, and two on the front. They do make a difference when folks are rolling around in bed on the other end of the camper! Also donít have to carry my cordless drill around anymore.
frostriver is offline   Reply With Quote
Old 03-18-2018, 10:02 PM   #19
I have electric stabilizer jacks. They're powered by an 18v Ryobi. :-)
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2019 F-250 XLT 6.2L 4x4 Crew Cab
mawilson is offline   Reply With Quote
jacks, power
