Old 10-31-2013, 09:24 PM   #11
First as for turning on the flush and walking away. My neighbor across the street in the campground did this another friend of mine drove by and saw a geyser coming out of the top of their camper. Turns out the neighbor turned it on and forgot to turn it off before returning home from the campground. It made quite a mess.
Upon saying this I do use the flush with the black tank closed and one thing it does do is emit quite a odor from the vent pipe. What i do is use the geo method as a tank cleaning system. 1 cup bleach, 1 cup detergent (liquid laundry), and 1 cup calgon (powder works best if you can find it). I add the ingredients and turn on the flush system to clean the tank then fill until the tank is full on gauges and then let it set for a bit. then drain the tank then close the valve and fill again to rinse. Then I rinse it again.
I have never had odor problems in my tank before using this method. Also an rv repairman told me another fix for a tank that has a lot of sediment in it. He uses rid ex to remove this stuff.
I do prefer the citrus chemicals for in the tank while in use though.
brokenaxle is offline   Reply With Quote
Old 10-31-2013, 11:01 PM   #12
abjb's Avatar
I think I found calgon powder on Amazon.
Amazon.com: Calgon Water Softener Powder, 40-Ounce (Pack of 2): Health & Personal Care
Is this what I want?
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 10-31-2013, 11:19 PM   #13
Denver, CO
garbonz's Avatar
Originally Posted by herk7769 View Post
Just my opinion, but I feel they are far more effective since with a clear elbow/section you can watch the tank empty until the water runs clear. The spinner inside the tank will make sure all surfaces are washed; not just the tank bottom as with a wand. FYI - As an aside, my turboflusher has a warning sticker not to run it with the valve closed. Not 100% sure why, but there it is. (Though a bit tough to read in my photo).
Since the tank is vented, the only possible reason is so you don't overflow the tank, when you forget to open the valve before the tank fills. Not that I ever did that...
2017 Fuse 23T
Old 11-01-2013, 07:11 AM   #14
MtnGuy's Avatar
ab&jb
I use the liquid. I can usually find it on the bottom shelf near the laundry detergent in Walmart.
http://www.walmart.com/ip/Calgon-Wat...-1-qt/13424609
Old 11-01-2013, 08:29 PM   #15
alphadog99's Avatar
Guess I should clarify - I'd never turn on the black tank flush and walk away. What I meant was as I start the flushing process, I'll turn on the intake to the flush system and let it run for maybe 30 seconds before opening the drain valve. I don't want a gusher coming out MY roof...
2016 Wildcat 29RLX
2011 GMC Sierra 2500HD Duramax CC
Banks tuner, airbox and filter
Rancho RS9000XL's and Firestone airbags
Pullrite Superglide 18k hitch
alphadog99 is offline   Reply With Quote
Old 11-01-2013, 08:39 PM   #16
Stank Bait's Avatar
The label by the hose connection on mine says to not use the flush system unless the drain valve is open.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 11-01-2013, 08:55 PM   #17
Herk7769's Avatar
If you do it; you should dump first; then close the valve while the turbo runs a while. If you are not sure how much liquid is already in there it can be up the stack before you know it is full to overflowing. This is how I do it when I am doing a "long flush."
HAM CALLSIGN - KC3FFW
Old 11-01-2013, 09:14 PM   #18
Denver, CO
garbonz's Avatar
I dump the tank and turn on the flusher then close the valve and set my watch for 5 minutes and go about the rest of the tasks, repeating the flushing until I am ready to pull out.
2017 Fuse 23T
Old 11-02-2013, 06:42 AM   #19
Herk7769's Avatar
Is it just me; but 5 minutes seems a LONG time. I would be worried that it would fill the tank before I got back.
I would rather dump; flush; close the valve while flushing for about 30 seconds; then open it; several times so the flusher actually impinges on the walls and sensors for the entire time. If you let the flusher fill the tank; the streams will only hit the surfaces actually above the water. Once the flush nozzle submerges you will get no wash action.
Old 11-02-2013, 09:38 AM   #20
Fulltime family RVer
I dump, run the flush for 30 seconds or so and then close the valve for 5 - 6 minutes (on a timer!). I opened it and repeat with a minute less of time on each flush until the water is running clear (usually 2-4 times).
The tank indicators have never registered above 2/3 in all my time doing it on my 42g tank.
black, black tank, tank
