Old 06-21-2014, 09:41 PM   #11
harpman's Avatar
I have an 2013 831 ress... the tabs are on the outside of the slides..they are pointed you push one down and the other up.. I forget which is which ... removes easily
831RESS FLAGSTAFF
F150 FORD ECOBOOST
harpman is offline   Reply With Quote
Old 06-21-2014, 10:12 PM   #12
VinceU's Avatar
Try to hold lever down one side at a time, don't pull draw out- push that slide into base. Repeat other side. May have to shake a bit but it will free. Leave a short amount of track hold the draw while you release the 2nd side.
