Old 06-21-2014, 06:18 PM   #1
bigben's Avatar
A little more help on drawer removal please.
We have a Flagstaff 2014, 831RESS. I need to fix a couple of drawers. I ready through the old thread about drawer removal. But still need more help.
Mine have the tabs - one pushes up, on pushes down. So I push down on the tab and up on the other - nothing. I pushed down and push up then pulled a little harder - nothing. I pushed down and pushed up pulled up and out a little harder - nothing.
Can someone help describe how i get the drawers out?
Thanks.
bigben is offline   Reply With Quote
Old 06-21-2014, 06:25 PM   #2
Post some pictures so we can get some idea of your problem.
Old 06-21-2014, 06:30 PM   #3
bigben's Avatar
I can put up a couple of pictures but it's pretty easy. The back of the drawers separated from the frame. A bit of gorilla glue and a small clamp job for about 3 hours and presto the problem will go away. It simply would be easier if I can get the drawers out. The slides all work, I'm just a little slow and cannot get them out of the slides to turn upside down to glue and clamp.
I can send pics but I just need to know how to get the drawers to release. If you still need pics I'll upload but honestly the mechanism works fine.
Thanks again.
Old 06-21-2014, 06:34 PM   #4
Originally Posted by bigben View Post
...but honestly the mechanism works fine...
Evidently not.
Your choice.
Old 06-21-2014, 07:03 PM   #5
bigben's Avatar
The pics
The first pic is of the back of the drawer that I've managed to repair. I wedge a piece of cloth up from the floor to hold the base in place while the glue dried.
The second is of the mechanism on the right side as you look at the drawer. The left side is the same mechanism but upside down.
Name:	back of drawer repaired.jpg
ID:	55957   Click image for larger version
Name:	Side Mechanism.jpg
Old 06-21-2014, 07:07 PM   #6
bigben's Avatar
One more pic of mechanism
Here is the pic.
Name:	Side Mechanism 2.jpg
Old 06-21-2014, 07:11 PM   #7
Send a message via MSN to Tiggerdad
I'll try to be a little more helpful. My drawers have the double extensions and a black plastic clip on each side. You are supposed to be able to push up on both extensions to raise a notch that keeps the drawer from coming out but the clips are too flexible to allow the notch to lift far enough,. If yours are this way use a small screwdriver under the long portion of the black clip and side of the extension. Then push the black plastic clip up and then slide the outside extension toward the back of the cabinet. The black clip is U-shaped and you must get close to the back of it to compress the clip enough for the notch to clear.
Hope this is clear.
EDIT: Yours is not like mine. When I clicked to post my response you had added pictures. Try a hardware or big box store to see if they have any like yours.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-21-2014, 07:12 PM   #8
bigben's Avatar
Do you need more info?
Old Coot is that enough? I can call my dealer or stop by but I feel fairly silly for not being able to pull these out
Old 06-21-2014, 07:13 PM   #9
Different from any I've seen. Might try prying it out instead of up or down.
Old 06-21-2014, 07:15 PM   #10
bigben's Avatar
Maybe someone else has seen
I saw this referred to in another thread but it was to old to reply to.
Anyone else had this problem?
