Old 09-21-2011, 06:36 PM   #1
Adding new tie down anchors
HI . I am buying a 27' xlr. ''short garage.Yes it's me Well Iwill make it fit. Here is the problem The anchor's are right above holding tank.Any ideas other than dropping the tank to add new ones THANKS
wing man is offline   Reply With Quote
Old 09-21-2011, 06:37 PM   #2
TURBS's Avatar
I am not sure I follow what your trying to do !
Old 09-21-2011, 06:54 PM   #3
adding tie down anchors
Iwant to add 2 new tie down anchors closer to interior wall but the tank is in same location. so i can not use bolts. Is there any bolt or lag out there.
Old 09-21-2011, 06:57 PM   #4
You'll have to use pictures or something, because I don't think we have a clue what you are talking about. Or just speak english.
Old 09-21-2011, 07:03 PM   #5
Can you read CANADIAN ENGLISH ''EH
Old 09-21-2011, 07:04 PM   #6
Eric F.'s Avatar
I am guessing you want to attach new tie downs to the floor, but the tank is directly below and you do not want to puncture?
Eric F.
2015 Flagstaff Shamrock 233S
2012 Ford F250
Eric F. is offline   Reply With Quote
Old 09-21-2011, 07:08 PM   #7
Lottery Non-Winner
Ovair's Avatar
He needs to install new motorcycle (or 4 wheeler) tie downs in the garage of his toy hauler. But drilling through the floor is a problem because the holding tank is right under it. How can this be accomplished? Will it require dropping the tank? Or is there a slick way to get around that hassle?
(I think that's the situation)
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 09-21-2011, 07:10 PM   #8
tie down anchors
Eric is right.
Old 09-21-2011, 07:13 PM   #9
OVAIR IS RIGHT.SO how can it be done.
Old 09-21-2011, 07:19 PM   #10
Eric F.'s Avatar
Looking from below, is there any way to see if the tank is flush to the floor or if there is a gap at all? Is there a space between tanks that you can bolt between?
Eric F.
2012 Ford F250
