Old 08-30-2011, 06:32 PM   #11
jimh's Avatar
Originally Posted by f1100turbo View Post
I'm not so sure he isn't talking about an over the air antenna that I have seen mounted to direct tvs actual dish. Its a horse shoe looking thing for local channels that you mount to the dish.
Which brings up a new thing. Is his tv old enough that it needs a converter box to receive signal?
i'm thinking the same thing. i'm really not clear on it.
jimh is offline   Reply With Quote
Old 08-30-2011, 07:07 PM   #12
TURBS's Avatar
would be nice to have some pics and more answers from the op
Old 08-30-2011, 08:51 PM   #13
If you have a rock wood A Frame camper . A few things.
The cable hookup is for cable coax or a digital television antenna.
It will not work with a satellite dish without a converter box inside the camper before you hook to the television.
Also, a regular non-digital television antenna (analog) will not work as nothing is broadcast in analog anymore and your flat screen will not tune it.
Make sure the flat screen in the camper has the right source selected (because it probably has more sources) If the wrong source is selected on the television, you won't get anything.
Have you verified the televisio works and can receive signals?
Work the problem backwards and eliminate possible problems as you go.
Lastly, I can't remember if the cable from the outside of the a frame to the inside connector is one piece of coaxial cable or if it's spliced at some point... It might be prudent trying to check that out too, once you've confirmed that the antenna works directly connected to the tv with a separate piece of coaxial cable.
Again, if it is a direct tv satellite dish you are connecting, I don't think that's going to work without the accompanying box and probably a subscription and some help pointing that dish I the right direction.
rawlus is offline   Reply With Quote
Old 08-30-2011, 08:54 PM   #14
Is this the antenna?
Old 08-30-2011, 09:29 PM   #15
TURBS's Avatar
I think its this but hey what do I know !
Old 08-30-2011, 09:50 PM   #16
jimh's Avatar
ie ur source selection may have changed when u unplugged it.
if u were working before u left, it should still work if there is a station in range. When it comes to aiming the antenna, Digital TV isn't as forgiving as analogue.
Old 08-31-2011, 04:21 AM   #17
You keep saying (He) I think it is (She). Youroo!!
youroo is online now   Reply With Quote
Old 08-31-2011, 05:42 AM   #18
jaxfl's Avatar
I don't think they have been back to this thread to get the answers or to answer the questions we asked.
jaxfl is offline   Reply With Quote
