Old 10-08-2013, 07:45 AM   #1
Air compressor
Can anyone recommend a small portable 12v or 110v compressor to maintain tire pressure on a class A motor home. My tires call for 125psi max and I try to maintain 110psi. Any suggestions would be greatly appreciated.
THELMALOUIE is offline   Reply With Quote
Old 10-08-2013, 07:58 AM   #2
Brother Les's Avatar
imo you will need a compressor with a tank on it. A small pancake would be the best, imo.
examples:
A Pancake Air Compressor - Compare Prices, Reviews and Buy at Nextag
Brother Les
Old 10-08-2013, 11:56 AM   #3
Craftsman 1.5 gal\150 psi max\25lbs\model#15309. 90.00 to 110.00. Check out Sears or Kmart got mine at Kmart it was cheaper than Sears. Fits in my cubby real nice.
sandpiper is offline   Reply With Quote
Old 10-09-2013, 08:18 AM   #4
Broken Toe
Cowracer's Avatar
I have one of those compressor/warning light dealys that plugs into the cigarette lighter. (like this)
It will actually reach 125psi, but don't be in a hurry. I got it for Christmas one year, and you would be surprised how many times that little POS compressor bailed me or other people out of a jam.
Very cheap, but light, stores anywhere, and pretty damn handy.
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 10-16-2013, 06:31 PM   #5
Send a message via Skype™ to Falcon35
I have one of these also I had to pick it up the USA because Sears Canada don't carry them. Has worked well for me.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 10-16-2013, 07:03 PM   #6
phat phrog stunt crew
do you have a class a diesel pusher with air brakes? if so, you already have the compressor and air tank. any shop should be able to plumb a fitting off one of your air tanks, then you would just need a quick disconnect fitting and a hose.
if not, harbor freight has pancake compressors for about 50 bucks. mine has done everything from running air nailers to airing up car,truck and rv tires. weighs next to nothing and takes up little space.
http://www.harborfreight.com/2-horse...sor-67696.html
with a coupon and a little haggling, you can get the price down. they dont appear to be set in stone.
i got this one for about 40 bucks with a 3 yr warrenty last year.
http://www.harborfreight.com/3-gallo...sor-95275.html
dwaynerz is offline   Reply With Quote
Old 10-17-2013, 04:52 AM   #7
ret2006's Avatar
I recently purchased this one. I actually have 3 other portable compressors but none would go to 150 psi. Now I have 4 compressors. This one is a winner in my book. Great for an RV, light weight, takes up very little room, will inflate the higher psi tires.
PORTER-CABLE CMB15 150 PSI 1.5 Gallon Oil-Free Fully Shrouded Compressor - Amazon.com
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 10-17-2013, 08:08 AM   #8
Originally Posted by ret2006 View Post
I recently purchased this one. I actually have 3 other portable compressors but none would go to 150 psi. Now I have 4 compressors. This one is a winner in my book. Great for an RV, light weight, takes up very little room, will inflate the higher psi tires. PORTER-CABLE CMB15 150 PSI 1.5 Gallon Oil-Free Fully Shrouded Compressor - Amazon.com
For that price it ought to be the winner!
Old 10-17-2013, 08:18 AM   #9
ryand's Avatar
Old Coot recommended the 12V/120V found at lowes....i bought it and it works well.
Shop Kobalt 12-Volt/120-Volt Dual Power Inflator at Lowes.com
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 10-17-2013, 09:06 AM   #10
kerrlakelover's Avatar
Before the OBX of NC pretty much became off limits to humans, we went down quite a bit and needed to air up the tires when we came off the beach. After some research, I picked up a Viair 400P Compressor Kit on ebay. They are not cheap (got mine for a pretty good price on auction), but they will air up big tires on a truck pretty quick. Viair has a pretty good following by off road'ers. Anyway, I made an adapter plug so I just plug into the 6 pin plug that's on my bumper. With the coiled hose, I can pretty much reach anywhere on the truck or 5ver. Only issue is that after you have used it, DO NOT touch the hose quick disconnect on the pump for a couple of minutes. It gets pretty hot.
Viair Air Ride Suspension Portable Compressor Kit 400P | eBay
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
