Originally Posted by NitroStar
This is the Compressor I have and used. It blew out the water pretty good through all the faucets then I done one at a time. I'm still concerned about the suction and discharge lines on the water pump that's under my bathroom sink. Just don't know much water is in pump and lines after running it with fresh tank empty.
http://m.craftsman.com/craftsman-3-g...p-00915362000P
As long as the water has a place to expand to - such as inside the non-pressurized suction pipe, it shouldn't be any issue as even FR shows that their piping systems can withstand freezing....
But I reverse blew air back into the suction pipe by opening the tank shut-off valve at the pump inlet, and blew air into and through the pipe that you would normally put into your antifreeze bottle. I could hear a little bit of water going back to the fresh water tank. It was just a little! Then it drained back and out thru the tank drain valve.
2012 Lacrosse, 308RES.
2013 Ford F150, XLT, 4x4, Supercrew, Eco-Boost.
Lee, Dawn and "CoCo", the dog!
2015 Overnight Camping Days = 25, States Below:
