Old 09-22-2015, 03:52 PM   #1
bes
Air Compressor on the Road
Hi Guys, not sure if this is the correct section so feel free to move if not. Anyone carry a GOOD portable air compressor capable of inflating tires to 90psi, in less than a day? Any input would be great. Thanks, Barry
bes is offline   Reply With Quote
Old 09-22-2015, 04:15 PM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
Name:   ImageUploadedByForest River Forums1442956388.718101.jpg
Take a look at this Viair 90P...I use on all vehicles from compact car, HD pickup truck to 5th wheel camper tires in the past...works great and is super portable.
Sent via Cajun Po-Boy's Tech Gear
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 09-22-2015, 04:18 PM   #3
Kenny kustom's Avatar
I would look at something a little bigger than a 90p.
It's only 120 max and has a duty cycle of only 15%.
For example, the 450 is 150 psi and 100% duty cycle.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-22-2015, 04:36 PM   #4
mcnabbwr's Avatar
I have this one and it really works well.
VIAIR Corporation - 400P-RV Automatic Portable Compressor (P/N 40047)
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 09-22-2015, 04:36 PM   #5
I use this. Works well...
2016 Siverback 33IK
Old 09-22-2015, 04:54 PM   #6
Camper Less Camping
OP...if you're mostly looking for an AC that can top off tire pressure within the +\- 5psi, the $80 Viair 90P will work great, otherwise, the 400P @ $200 will do a better job handling larger inflations and the coil hose makes it much easier to reach longer distances from a battery source, eitherway, Viair products are top notch
Old 09-22-2015, 06:47 PM   #7
HONDAMAN174's Avatar
Saw one of those 400p's on Amazon for $161
Looks like a nice unit. But I am running a 1000w inverter and 120v inflator already. Still need to get an electric impact from HF.
Just glad to get away
Old 09-23-2015, 12:27 PM   #8
Thumbs up
Originally Posted by Cajun Po-Boy View Post
Attachment 89601
It works great.
bear11 is offline   Reply With Quote
Old 09-23-2015, 01:00 PM   #9
I am a retired building contractor so I had a small pancake air compressor that goes up to 150 psi
it works very well, does need 120v to run but is much faster than 12v models
Mstrshop1 is offline   Reply With Quote
Old 09-23-2015, 01:03 PM   #10
I carry a Porter Cable pancake compressor, 120v and 150 PSI - that contractors use for their nail guns. Also have a genny to provide the AC power.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 09-23-2015, 01:27 PM   #11
BamaBob's Avatar
I'd get this one if I were you:
http://www.amazon.com/gp/product/B00...rch_detailpage
Oh, wait, I DID get that one
AND it inflates to 80PSI in something like 35 SEC
Seriously, get a compressor that has a tank and goes to at least 125PSI (This one goes to 150)
Nights Camped: 2013 - 24 ē 2014 - 42 ē 2015 - 56 ē Jul 2016 - Fulltime ē
BamaBob is offline   Reply With Quote
Old 09-23-2015, 02:03 PM   #12
Fulltime family RVer
Thanks for this thread; it reminded me that my existing Porter Cable pancake compressor wouldn't put air into my tires over 110psi (though it's rated to 135psi).
For anyone wondering about a Viair compressor; go to their website and use the live chat feature. The rep was amazingly helpful and helped me spitball ideas for what would be best for me.
I'm ordering the Viair 450P here shortly.
ependydad is online now   Reply With Quote
Old 09-23-2015, 02:17 PM   #13
Air Force Retiree
I carry a 12V 150psi compressor that Harbor Freight Sells. It fills me 90# tires with no problem. Nice part about is the air hose valve adapter screws on to the valve core, with a gage in the line, that way you don't have to sit there holding it on. Once my tire reaches 90#, I unscrew the valve adapter from the valve core and the turn of the pump. These are on sale at $59.99 now. Here's the site for it: 12Volt 150 PSI Compact Air Compressor
Retired Air Force is offline   Reply With Quote
Old 09-23-2015, 02:43 PM   #14
DaveSchwartz's Avatar
I bought one of the dual-voltage Kobalt's on sale at Lowe's when I knew I'd have to air-up progressively on a return winter trip from Florida. Worked great on 120VAC at campgrounds, also worked great on 12VDC 300' from the nearest outlet in the middle of a hotel parking lot in Morgantown WV. I inflated my TV rear tires to 80psi and RV to 65 (because I knew the temperature would be dropping even more that day).
I know OC will add that he's talked to people who had early-life failures with these, but that's my direct experience.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-23-2015, 03:11 PM   #15
dieselguy's Avatar
I've used the Harbor Freight model for several years as well. Airs up my LT 235 R16's with little wait. Just be sure and check the head bolts when new ... most are loose.
dieselguy is offline   Reply With Quote
Old 09-23-2015, 03:17 PM   #16
I had the Craftsman 120V Portable Inflator for ten years and it did the job.
This summer it died. I bought another inflator while on the road from AutoZone and I'm not happy with it. I am now trying to purchase the Craftsman 120V but it must be a hot item because I am having a problem connecting with one.
BTW- if you are traveling without a means of inflating your tires, and if you are not checking the tire pressure before hitting the road.....you are flirting with disaster.
Big Shoe is offline   Reply With Quote
Old 09-23-2015, 05:24 PM   #17
bend302's Avatar
I got that one as well.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 09-23-2015, 06:13 PM   #18
dicky1243's Avatar
I bought a 6gal compressor at Harbor Freight 100.00
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 09-23-2015, 06:19 PM   #19
nomad297's Avatar
I bought that one once. It caught on fire during my second use filling my 80 psi truck tires from 65 psi.
Bruce
Old 09-23-2015, 06:28 PM   #20
RETIRED
n-e-d's Avatar
X2 Its what I carry along with 50' of hose
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
