Old 04-08-2013, 02:51 PM   #1
Air conditioner run off help
Has anyone come up with something that will collect the water from the air conditioner? Looking at maybe a bucket we could connect PVC pipe/hose to so we can drain away from the camper. Right now we either end up with a mud pit or a wet deck depending on what we're doing. Getting to old to carry a bucket of water around to dump somewhere.
jmswms is offline   Reply With Quote
Old 04-08-2013, 03:25 PM   #2
lindy's Avatar
I just slope the trl a little toward the rear and the left, that way the AC water drains off the back corner of the trl where we seldom walk.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 04-08-2013, 05:01 PM   #3
X2
Old 04-09-2013, 03:55 PM   #4
Tried that and it doesn't work at our semi-permanent site. We either have a mud hole that runs down the hill that other people walk through-not pretty or we have it splash on the deck-not good for deck
Old 04-09-2013, 06:05 PM   #5
Fulltime family RVer
I've tried putting a small pile of rocks where the runoff goes to, at least, dissipate it. Still hasn't helped a whole lot.
Any thoughts on doing a simple rainwater collection bucket?
Or, you could take a tip from the homeowner we bought from. He had a leaking tub above the HVAC duct work. He took a cookie sheet and set it on top. On that, he put a tupperware container about 6" wide x 10" long and about 2"-3" tall. He put a layer of small gravel in the bottom of it. In the side of it, he cut a hole near the bottom and glued a clear vinyl tube to it. He ran that vinyl tube to the laundry room sink. You could do the same only run the tube to somewhere convenient. Only- I bet you a dollar I'd trip over the friggin' thing.
Old 04-09-2013, 06:17 PM   #6
TURBS's Avatar
Ok I cant stand it .............. I was hoping you guys would come up with this ..
take a length of small diameter rope and and attach it to the gutter spout then let the rope dangle to a bucket which has a plastic hose barb fitted on the side towards the bottom, then attach a hose to the hose barb and run it out 15'
problem solved .
Man I gots to teach you guys everything ?
Old 04-09-2013, 06:31 PM   #7
Mountainmanbob's Avatar
that rope should work just fine
it works
a small amount of water will follow the string or rope
many years ago when I was young and next to poor
the roof starting dripping
yes of all places
right into the middle of the bed
wrapped some string around a thumb tack
stuck it into the ceiling where the leak was coming from
wrapped the other end around a brick in a large pan
we would lay in bed dry
as we watched the water drip down the string into the pan
glad those days are over
but
one does what one has to do
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 04-09-2013, 07:08 PM   #8
problem solved .
Turbo,I guess you are going to tell them about the (Clothes Pin ) trick on the gutter spouts to avoid Black Streaks on the RVs! Youroo!!
Old 04-09-2013, 07:24 PM   #9
TURBS's Avatar
NOT until I cant take it anymore !
Old 04-09-2013, 07:54 PM   #10
AquaMan's Avatar
problem solved .
All I can think of is "Forest Gump", "...and I taught her to dangle." lol
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 04-10-2013, 11:32 PM   #11
Aunti-Mgeorge's Avatar
Well. How long do
We have to wait to hear about the clothes
Pin???
Aunti-Mgeorge is offline   Reply With Quote
Old 04-22-2013, 02:49 PM   #12
JeffMc's Avatar
+1 on the clothes pin! Attach to your gutter downspouts and the water will run off the end of the clothespin and not down the side of your trailer!
Jeff and Dana McCreary
2004 F-250 SuperCrew Lariat 6.0 Diesel
2003 Cardinal 312 BH
JeffMc is offline   Reply With Quote
Old 04-22-2013, 02:50 PM   #13
TURBS's Avatar
Yep!
Old 04-22-2013, 03:29 PM   #14
MI Camperz
bodzcampers's Avatar
It didn't happen unless there's pictures.
Plus, I don't quite get it. So, pictures plz. I want to keep water off the deck. Don't want anyone slipping at the Hoe Downs.
MI Camperz
bodzcampers is offline   Reply With Quote
Old 04-22-2013, 03:50 PM   #15
TURBS's Avatar
Clip the clothes pin to these.
Old 04-22-2013, 03:55 PM   #16
MI Camperz
Clip the clothes pins to them there downspouts?
Clearing throat............Can you be more specific?
Right on the ends? Plastic or wood? Does it matter?
MI Camperz
Old 04-22-2013, 04:01 PM   #17
TURBS's Avatar
Right on the ends plastic or wood doesn't matter
Sometimes 2 pins per spout will work if it ain't real windy.
Old 04-22-2013, 04:04 PM   #18
MI Camperz
Two pins in a row, one attached to the back of the other? Or, two pins coming off the spout separately?
This is inspiring me to invent a tubing apparatus like a gutter drain tubing thing.
Can use french drain type tubing if you want a RN splash park.
For the rope method, do you use nylone rope, cotton rope, twine rope, or doesn't matter?
MI Camperz
Old 04-26-2013, 07:25 AM   #19
that's what we do also then put a pail there. On my seasonal lot I have collected stones from the beach to let the runoff go so there isn't erosion.
brokenaxle is offline   Reply With Quote
Old 04-26-2013, 11:30 AM   #20
I elected to put a flower and flower pot under the drip. I never have to water it and it looks nice.
Waterfowlwarrior is offline   Reply With Quote
