Old 08-22-2014, 05:34 AM   #1
mrmichael's Avatar
Another Inverter question
Hi everyone. Relatively new Rv'er here but many years of car and tent camping. We recently bought our 2109s (and loving it). I had thoughts of adding an inverter, mostly just to be able to run the fridge while driving. Have done and will be doing some long travel days and usually have a well stocked fridge and freezer.
Camper is new and added a second size 24 deep cycle battery in parallel. I would think I could have an outlet from the inverter in or near the fridge compartment and just switch the plug that it's plugged into.
Any idea how big an inverter would be needed? Will my truck recharge the batteries while driving? Any downsides? Thanks
Michael
mrmichael is offline   Reply With Quote
Old 08-22-2014, 05:58 AM   #2
TURBS's Avatar
Michael
Why don't you just run it on gas like everyone else.?
TURBS
"SABRE OWNERS UNITED"
Old 08-22-2014, 06:03 AM   #3
Why not run it on propane? I would say the majority of people on this form run there fridge on propane while traveling. As far as your question, I think the fridge uses about 240W to run, that is a 20A draw at 12V, most TV's are not wired to give you 20A to your trailer. You would need to run a large gauge wire from your TV battery to the trailer connector.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 08-22-2014, 06:09 AM   #4
Grn_Mtns's Avatar
We have a TT and have put a couple hundred thousand miles on several models all while leaving the fridge lit on propane while driving.No problems so far!
I would use a 1000 watt inverter and the truck will most likely only trickle charge the battery so they will run down without installing some heavier charging wire back to RV...We always install one anyway & You will enjoy 110 when you are away from shore power for all the electronic toys! We have a 260 watt solar panel on the roof that helps out alot. Good luck & enjoy the new RV.
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
Grn_Mtns is offline   Reply With Quote
Old 08-22-2014, 07:03 AM   #5
mrmichael's Avatar
Thanks for the replies. Not real comfortable with the thought of driving around towing an open flame but that seems to be the way to go. Of course will have to remember to turn it off when stopping for gas
Michael
Old 08-22-2014, 07:05 AM   #6
TURBS's Avatar
Michael
I dont.
TURBS
Old 08-22-2014, 07:07 AM   #7
mrmichael's Avatar
Old 08-22-2014, 07:09 AM   #8
TURBS's Avatar
I know I'm a rebel.
TURBS
Old 08-22-2014, 07:09 AM   #9
mud yapster's Avatar
I don't either the flame is contained inside the refer behind the panel.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-22-2014, 07:41 AM   #10
Kaadk's Avatar
Me either. Gotta remember 3 things:
1) They don't use pilot lights, they're on demand. So they're actually only flaming while cooling. Can't be any more than 1/3 of the time and probably much, much less. The chances of having a flame on at the time of fueling is not as big as most people think.
2) It's covered, contained, and well off the ground. It's gonna take a lot of gas vapors to reach that flame.
3) What's the distance between the fridge and your gas tank? In my case, it's like 30'. My fridge is often no where near the actual pumps.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
inverter
