Old 10-25-2014, 02:03 PM   #1
derek6669's Avatar
Another winterization question
What is the best practice concerning coach batteries when storing over the winter. Leave in coach or remove and store in heated area?
derek6669 is offline   Reply With Quote
Old 10-26-2014, 06:27 PM   #2
Boss Hoss's Avatar
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 10-26-2014, 06:34 PM   #3
Ford Idaho's Avatar
You can leave them in IF you are going to leave the MH plugged in or a battery tender on both coach and chassis batteries.
Just be sure to keep an eye on the water level unless you have jel type.
Old 10-26-2014, 07:28 PM   #4
Crusadernoob's Avatar
If my battery is going to sit more than a week I take it home and put it on a maintainer.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 12
Crusadernoob is offline   Reply With Quote
Old 10-26-2014, 08:05 PM   #5
Lets establish a couple things before a recommendation.
Usually motorhomes (intent of this post) have at least two group 27 batts. They are usually strapped, with multiple terminal connections, so removal in this senario is not a snap.
We'll assume your going to long term store them, as in a winter season lay over senario.
You would need to put a trickle charge on them, as batteries lose a charge even at idle (left in or removerd) over long periods of time. Faster discharge left in, due to parasitic demands in most cases.
So, assuming all of the above, the simple route is to hook up a cheap trickle charger (or spend bucks on a more expensive one, if that makes your comfort level increase) to just one of the batteries, as they are still connected and the trickle current will buffer between the two (or more) batts. A few things you need to do; fully charge your batteries and remember to check water levels before the storage period. ONLY add distilled water if needed, and check periodically over the winter, lets say once a month. A fully charged battery can withstand extreme low temperatures. This very senario has treated me well for years.
winter, winterize
