Old 03-25-2016, 05:42 PM   #1
Any "Must Haves" as new RV'ers?
We recently purchased a 2008 Cedar Creek Silver Back 30LSTS. It will move us from Nashville, TN to Seattle, WA over the course of about 2-3 months for work. We're definitely going to see some of the National Parks along the way, but will also be working in the different cities along the way. Besides the obvious water hose, sewage hose, water pressure regulator, blocks to chock/ level...what else have you found that I'll be thankful I had, or made everyday type RV living much more easy? I'm open to suggestions on nearly anything, as it's ALL new to us!
Thanks in advance!
Trot27 is offline   Reply With Quote
Old 03-25-2016, 06:11 PM   #2
Ford Idaho's Avatar
Electrical Receptacle Tester with GFCI Diagnosis
11 Function Digital Multimeter with Audible Continuity
Spare bulbs for every type inside and out as well as fuses.
A ladder.
https://www.google.com/url?sa=i&rct=...59034033538032
A cordless drill and bits
18 Volt 1/2 in. Cordless Variable Speed Drill/Driver
https://www.google.com/url?sa=t&rct=...dZCekhQJWU0dYg
A roll of Gorilla tape.
Old 03-25-2016, 07:09 PM   #3
Fulltime family RVer
This may already cover what you already know:
http://www.learntorv.com/2014/02/new...ssentials.html
I'd also recommend a tire pressure monitoring system, a Progressive Industries EMS (like a badass surfer protector), air compressor, tire gauge (cheap digital gauges are generally better than the stick type ones), a plan for changing tires and equipment to perform that plan, torque wrench, short breaker bar, and awning support poles from either OldCoot or TURBS.
ependydad is online now   Reply With Quote
Old 03-25-2016, 07:43 PM   #4
A tool box full of tools. (wrenches, ratchet and sockets, screwdrivers, wire cutter / stripper, Vise grips, 12V test light).
Variety of spare fuse.
Dicor sealant and Eternabond roof patch.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 03-25-2016, 07:47 PM   #5
Capt. Mike's Avatar
And zip ties...can't ever be without zip ties...they will fix most everything.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
ďIt's not how old you are, it's how you are old.ĒJules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 03-25-2016, 07:48 PM   #6
nuisance's Avatar
a 2 or 3 step step ladder, RUKO for watching tv, weather radio, extra batteries for everything, full propane tanks
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 03-26-2016, 10:15 AM   #7
Left Coast
Robertson screw driver bits.....(square drive screw are threw out RV)
Old 03-26-2016, 12:05 PM   #8
Lots of PATIENCE.
ezitin is offline   Reply With Quote
Old 03-26-2016, 12:15 PM   #9
A selection of hand tools. Extra hoses. Checklist for setup and tear down. Simple digital multimeter 4 chocks. Transparent black hose connector for flushing. 2 hydraulic jacks 20 ton. Wood blocks. This will get you started.
Harkerr is offline   Reply With Quote
Old 03-26-2016, 12:17 PM   #10
Also do not be afraid to ask for help. We have all been in your shoes.
Old 03-26-2016, 12:22 PM   #11
One or two quality inverter generators. A broom for dirt and snow on the floor and slides. Rope. Couple fo 5 gallon fuel containers. Some solar lights that are motion activated over the door and tongue. A can opener\multi tool. An electric space heater or two. Containers to place all your can goods and stuff inside the storage compartments so they do not go flying all over the place when towing. I use empty milk\water jugs to take up space in drawers and cabinets to prevent damage or movement. Lots of flash lights scattered around the RV and TV. Cardboard boxes folded flat to set your generator on or store things while in transit. Lots of storage and garbage bags. Grocery bags too.
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
Old 03-26-2016, 12:25 PM   #12
CarolinaGirl's Avatar
1. Tension bars for the refrigerator to keep stuff from falling over and moving around.
2. Small baskets or plastic bins to also keep stuff from moving around in cabinets and cubbies.
3. Multi-purpose lighter with the metal wand for lighting camp fires, gas grills or oven in camper.
4. Stuff to do on rainy days when you might be stuck inside your camper, i.e. cards, puzzles, crosswords, board games or whatever else floats your boat.
5. Big cooler in case you have any problems with electricity or refrigerator.
6. Some kind of mattress topper because most RV mattresses are super uncomfortable.
7. One of those big camping mats, door mat, or both so you don't track in a ton of dirt or gravel into your new rig. You'd be surprised just how much stuff gets tracked in even in 1 day when you are on a site that is something other than grass.
8. Tablecloth that will fit a picnic table and some clamps to hold it on (in case it is windy). We've discovered that some picnic tables can be pretty gross, even if the campground is nice.
9. Enough camping chairs for everyone who will be camping with you, just in case there is no picnic table. That way you'll have a place to sit outside and eat and of course for sitting around a campfire.
10. This one isn't a necessity but we use them on pretty much every trip. Smores sticks! My kids love having their smores, but I'm not a fan of using random sticks. So, I found something similar to this. I have a store near me that sells them in a pack of 10 for $1.00 but I'm posting this link so you can see what I'm talking about. http://www.amazon.com/MalloMe-Marshm...hmallow+sticks
Happy camping!
No Longer Newbies
2016 Trips:16 Nights:41
2015 Trips:13 Nights:29
2014 Trips:13 Nights:31
CarolinaGirl is offline   Reply With Quote
Old 03-26-2016, 12:30 PM   #13
Not sure what the parks are like down there but in Canada, 100 feet of power cord. They save money by making you provide the cable.
RussPastuch is offline   Reply With Quote
Old 03-26-2016, 12:37 PM   #14
Ford Idaho's Avatar
I have not needed to use more than the 35 feet attached to the lite.
I have extra just incase......
Old 03-26-2016, 12:39 PM   #15
RETIRED
n-e-d's Avatar
Camco screen door cross bar and 50' of coax cable
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 03-26-2016, 12:55 PM   #16
Dahagen
Sounds like this forum has already loaded you down. But don't forget AC power adapters. Some parks have only 20 or 30 or 50 amp service. You need to be able to hook up to any style plug.
dahagen is offline   Reply With Quote
Old 03-26-2016, 01:07 PM   #17
Thanks in advance!
I use a lot of electric appliance and use campground electric, saves propane.
Myrle is offline   Reply With Quote
Old 03-26-2016, 01:33 PM   #18
Most importantly, in my opinion, is having plenty of time off or free time to enjoy your new RV!
philobeddoe is offline   Reply With Quote
Old 03-26-2016, 02:22 PM   #19
30 Watt Solar panel with good waterproof controller. I mounted mine over the battery in the front and it keeps my battery up over the winter without pulling it out.
randman132 is offline   Reply With Quote
Old 03-26-2016, 02:29 PM   #20
BandJCarm's Avatar
Plenty of ice and a camp chair for me to sit in when I visit.
An immoral brother-in-law that's a banker (this is your biggest need!)
A name plate so I can find you at campsites (I can't find one I like, however).
All the above in jest. I am making my own list, and I've added about 20 items to it since this thread started. Very good stuff. Thanks, everyone.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
newbie
