Old 12-14-2014, 08:32 PM   #11
dcheatwood's Avatar
Alcohol or hand sanitizer help.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 12-14-2014, 09:07 PM   #12
Taranwanderer's Avatar
The trick with WD40 is to let it soak for a while--15 min or so, then wipe off. Good luck!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 12-15-2014, 11:31 AM   #13
WD 40
firstclark is offline   Reply With Quote
Old 12-15-2014, 11:43 AM   #14
All of the suggestions will work with time, but the best product I have ever seen for this type of need is called Contractor's Solvent. It looks and smells similar to Goo Gone but works much faster. It will remove any sticky residue quickly and easily.
Backpacker
glfillion is offline   Reply With Quote
Old 12-15-2014, 04:04 PM   #15
Goo-Gone, WD-40, Liquid Gold
sailtrkr is offline   Reply With Quote
Old 12-15-2014, 04:57 PM   #16
Ret E-9 Anchor-clanker
donanddona's Avatar
Tried peanut butter?
donanddona is offline   Reply With Quote
Old 12-16-2014, 09:29 AM   #17
tips for removing adhesive residue from sticker
I am surprised nobody mentioned Acetone, it's cheap
jim-bob is offline   Reply With Quote
Old 12-16-2014, 09:35 AM   #18
jim-bob I'd say acetone is a little aggressive for fiberglass gel-coat. I know I won't use it on fiberglass. ( just my thoughts )
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-16-2014, 10:02 AM   #19
Oklahoma Proud
MillerTime's Avatar
Yeah, dont use acetone, its used to reduce and will "re-wet" gelcoats, resins and some paints. It will soften it and you will have to wax it to get it to cure back.
Old 12-16-2014, 10:03 AM   #20
Acetone fiberglass
Sorry I disagree, used it on my Searay boat for years could not see any damage what so ever, some cleaners mentioned have acetone in it.
