Old 04-24-2014, 04:48 PM   #1
BombDoc's Avatar
Anyone else using large blocks like this?
Helped a friend "set up" his 5'ver a couple weeks ago. As he backed into his site, I noticed a pile of blocks in the rear of his truck bed. I asked him what he had all the stock for. His response, I'll show you. As we set up, he stacked the blocks together and barely lowered his jacks. I asked why, his response "minimal movement". So I had to try. A couple weekends ago, I did the same thing and I have to admit, I like it. Reduced the movement dramatically. I think I will take them along from now on. Not as heavy as they look but it worked.Click image for larger version
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 04-24-2014, 04:54 PM   #2
Resident Masshole
force's Avatar
There's a sawmill down the street from me that has a ton of these stacked up for sale. I haven't picked any up because the seem a little big to carry around in my truck, but if it does reduce the camper movement as you say, guess I'll have to reconsider.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 04-24-2014, 04:56 PM   #3
Talking
I don't know if the block stack makes it stable, but when you go to do the pull test, as you should for a 5th wheel, it's going to be a long drop to the ground. That if the hitch didn't hook. I just use a 2x under mine and have a tri-pod stabilizer. I do use big blocks under my back stabilizer.
southernsky is offline   Reply With Quote
Old 04-24-2014, 04:59 PM   #4
BombDoc's Avatar
I as well as DW immediately felt a difference. We had some friends over and they had little ones running around. It would have been miserable if I had just set up like normal using a 4" X 6" block. This was much better and all 8 pieces lay flat between my hitch and the tailgate. I'm going to make some homemade x chocks to go between the tires and I'll be set. It worked best when we were in the bed. Whenever one rolled over, it was way less movement than before.
2013 Sabre 32RCTS-6
Old 04-24-2014, 05:00 PM   #5
Resident Masshole
force's Avatar
I have scissor jacks, and I'm guessing the less you have to extend them, the less movement you'll get from them flexing. I don't expect to achieve zero movement, but any reduction is a bonus in my book.
Edit: Thanks for the feedback BombDoc, that's exactly when I want reduced movement...bed time!
Tom F.
Old 04-24-2014, 05:04 PM   #6
NELA
Weezer's Avatar
We've been using the big wooden blocks under our rear stabilizers for a while now. It seems I read here somewhere that the less the stabilizers are extended, the less movement there will be.
works for us
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 04-24-2014, 05:05 PM   #7
I use 6x6s doubled up under my scissors and it is alot more steady that a longer extended jack. Just make sure that you stack them at 90 degrees to the last row... Quite a bit stronger..
Camped: 2019 (Days/Nights) - 27/20
2018(D/N):24/17, 2017 (D/N):30/25, 2016 (D/N):32/23
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
Old 04-24-2014, 05:20 PM   #8
JT Strong Arm type stabilizers will do the same and eliminate the need for the big blocks. The electric stabilizers in the rear when they have blocks under them are subjecting the legs to the most leverage to bend them at their weakest point and if for some reason or other the front landing jacks are extended inadvertently, the rear jacks will bend. I reinforced the legs and try to get them at least to 45 or greater. JMO
Old 04-24-2014, 05:23 PM   #9
Toy-aholic
I've been using 6x6's under my frt jacks since day 1...made a HUGE difference in side to side sway
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 04-24-2014, 05:25 PM   #10
BombDoc's Avatar
Thanks for the opinion, that's what I was looking for
2013 Sabre 32RCTS-6
lock
