Originally Posted by Chaplain Kent
With our rental business I took each new unit with two people one inside and one out. We used a bright spotlight to find every hole, crack, and crease and fill with steel wool. Then swapped the light source to the outside and repeated the process. On a ten foot pop-up I would use a couple bags of steel wool. If you are able to find hedge apples (you can tell I am a Midwesterner) they will repel both the rodents and the spiders. Next problem is Chipmunks who will gnaw through the floors.
Mostly a myth...
Facts and Myths about Hedge Apples
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
