Old 04-26-2019, 09:33 AM   #1
Awning in or Out?
I'm rather cautious with the use of my awning because I've seen a couple of cases of severe wind damage on rigs when owners left their awnings extended and weren't there when the wind came up. I've seen awnings left extended most of the time, I've seen them hardly used at all, and I've seen everything in between. I tend to keeping it retracted most of the time, especially when there's any breeze blowing. Am I being overly cautious? How/when do you extend your awning? I'm curious to learn if there's a preference among users of this forum. Thanks.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 25 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 04-26-2019, 09:36 AM   #2
we use our a LOT in the desert, even in moderate winds. I have a tie down system I use and we can keep it up when most are taking theirs down. I also park with that side of the trailer downwind. That being said I rarely leave it down at night or when we leave for an extended ride. Some manufacturers offer a wind sensor option and it works well.
nayther is offline   Reply With Quote
Old 04-26-2019, 09:39 AM   #3
You'll find that everyone kinda does their own thing. In-Out-Tied down. I personally put it in if we're leaving for awhile or at night. If it's gets really windy I'll put it in or If I see storms are forecast, I'll watch weather and put in as needed. I too have seen dumpsters full of destroyed awnings and canopy's at CG's over the years. Too expensive to take a chance...that's just me.
TheWolfPaq82 is offline   Reply With Quote
Old 04-26-2019, 09:45 AM   #4
RACarvalho's Avatar
Ours is out all the time, except if high winds are expected.
One thing I learned is that if you tilt it down both sides, it gets way more stiff against the winds.
So now if we are leaving the campsite and forecast is not saying high winds but I suspect it is wrong, I tilt it down both sides.... That also helps with rain...
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
RACarvalho is offline   Reply With Quote
Old 04-26-2019, 09:51 AM   #5
CentralMePistol's Avatar
Being someone who has lost one... use caution!
The one that was lost was the old style, pull down then raise support arms. I had even tied it down... Then came a freak and massive thunder storm while we were away from the camper. So much water came down so fast that it snapped the roller! Water had gather even though I had it lower (slightly) on one side.
This storm was so strong that some of the tent campers in the area were literally washed down the hill. CRAZY!
Now I have an electric extend and retract that has a spring mechanism in the case of too much water. That said I am still careful to this day of water and wind with the awning out... I rarely leave the camper with it extended but will go the night if no storms are called for.
2018 Cherokee 274DBH
2012 GMC Sierra 1500
4x4, Crew Cab, 5.3 KDL HD Cooling, 3.42 ratio
Recurve R6 WDH w/Sway Control & SumoSprings
Days Camped:2019-18 and counting / 2018-30
CentralMePistol is offline   Reply With Quote
Old 04-26-2019, 09:52 AM   #6
Georgia Rally Coordinator
aceinspp's Avatar
I also have a awning hold down system that allows me to leave out up to around 35 mph winds. If I know storms are in the area then I will put in. Most times I will put in when we leave for part of the day just in case weather man misses his mark, which is most of the time Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 30
Old 04-26-2019, 10:00 AM   #7
Capt. Mike's Avatar
What RJ said ^^^^^
We use tie-downs when we are around the campground (although I think 35 mph wind is a little high), but if we are leaving I'll put it in. Our little white dog likes to have it deployed if she has to go outside to pee in the rain.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
ďIt's not how old you are, it's how you are old.ĒJules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 04-26-2019, 10:04 AM   #8
We do not use ours a lot. Error to the side of caution.
During our first year in the fifth wheel we saw a destroyed awning near most of the dumpsters. That influenced me.
tomkatb is offline   Reply With Quote
Old 04-26-2019, 10:29 AM   #9
We have the awning tie down brackets and poles that were being sold a few years ago by two forum members, Old Coot and Turbs. Both seem to have sadly left the forum.
With the brackets and the poles for stability, we can leave our awning out all weekend in most cases. Yes you need to use caution if a storm comes through but it allows us to maintain cover across the front of our R/V.
Do a forum search on awning brackets and poles and you will have days of reading.
Name:	awning poles_002.jpg
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 04-26-2019, 10:43 AM   #10
Denver To Yuma In 90 Days
I've seen them ripped away by the wind too many times out here in the wild, wild west.
My awning only goes out if I'm using it.
It gets put in at night or if I leave the campsite...even for a bike ride around the park on a clear sunny day.
I almost lost the awning on my previous camper while bike riding around the campground at St. Vrain State Park in Longmont, Colorado.
Was clear on the other side of the park when a freak wind blew through.
Just barely got back to the TT in time before it almost flipped over the top.
Ironically, that was the first of two wind events at that campground while I was there...both July 4th. weekends one year apart.
The other took out just about every slide topper and any awning that was left extended in the entire park...
But that is another story...
Only takes one game of chance for me to learn my lesson...
JohnD10 is offline   Reply With Quote
awning
